Zum Hauptinhalt wechseln
The Razer Blade 15" Base Model (2020) is a powerful gaming laptop, with a 10th gen, 6-core, 5.0 GHz Intel processor.
Adding USB-C charging option externally
I've seen some adapters around that connect to Razer's proprietary connector, and was wondering if anyone has attempted to use a USB-C PD board to charge the laptop? I mostly use my laptop portably in Linux without use of the discrete graphics so I only require <100W of power which USB-C can provide. But unsure whether the charging port will accept less than the 230W that comes from the regular charger
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Would love an update on this!
von
Einen Kommentar hinzufügen
1 Antwort
@lachlanhogan It depends how razer has their power management set up, with other brands such as Dell they force the CPU to throttle a huge amount if it's not connected to the correct power supply, either you'll get lucky or it won't be usable unfortunately.
Thanks! :)
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Lachlan Hogan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 532
