Zum Hauptinhalt wechseln
Repair information for Sony Bravia 32" LCD TV. Released in 2008. Model number: KLV-32T400A.
20 Fragen Alle anzeigen
Tv will be automatically off
TV it will be automatically off
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
@santoshull69133 what is the exact model number for your TV? What have you checked? What have you tried? Explain to us exactly what happens. You chin your TV on and it turns right back off? Does the power LED blink? Any specific code?
von
Einen Kommentar hinzufügen
1 Antwort
Firstly, check if you have unknowingly set an automatic shutoff timer in the TV settings. If that's not the case usually this symptom is indicative of faulty capacitors on the mainboard or power board of the TV at least with Samsung TV's. I suspect similar symptoms could occur on Sony TV's as well, If you're comfortable with doing so, you can open up the TV and check for any bulging capacitors on both the mainboard and the power supply board.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Santosh Ullagaddi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 30
