Zum Hauptinhalt wechseln
LiDAR won’t spin
The LiDAR will stop spinning. This seems to be a common problem with their design. Sometimes it’s debris that gets into the housing. Others the motor blows out. There are YouTube videos showing repairs on older models but none on this model. A video would be helpful as the design seems to be slightly different.
Also, any advice on upgraded replacement parts to fix the weak points would be helpful.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Check this up.
https://www.reddit.com/r/Roborock/commen...
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I fixed it. Thankfully these are pretty easy to disassemble. There was a tiny hair in the rubber band pulley. It’s worked great since that one issue when I first got it. Highly recommend.
von Teilen
Antwort hinzufügen
BuildItRight wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 74
Insgesamt: 421
