Zum Hauptinhalt wechseln
iSight light is always on
The green "camera is on" iSight light to the right of the iSight is perpetually on! I know that the camera is not actually on (the cable is not even connected), but it is still unnerving. Any ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
the fact that the camera is disconnected does not stop the rest of the circuitry to switch off / on. So is the camera actually on when you connect the cable?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You should try disconnecting the cable to the light (if possible) and reconnecting it to see if that helps
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Well, this didn't fix the problem, but it gave me the motivation to open the machine and disconnect the cables. The light is definitively off now! Thanks!
von
I can see you!
von
Antwort hinzufügen
Ben Eisenman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,568
