Zum Hauptinhalt wechseln
Google Pixel 9 Pro Fold Outer Screen Replacement
Was du brauchst
  1. Google Pixel 9 Pro Fold Outer Screen Replacement, Prepare your phone for disassembly: Schritt 1, Bild 1 von 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
    Frag FixBot
    Kommentar hinzufügen
  2. Google Pixel 9 Pro Fold Outer Screen Replacement, Insert an opening pick: Schritt 2, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement, Insert an opening pick: Schritt 2, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement, Insert an opening pick: Schritt 2, Bild 3 von 3
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • Insert an opening pick into the gap.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
    Frag FixBot
  3. Google Pixel 9 Pro Fold Outer Screen Replacement, Separate the adhesive: Schritt 3, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement, Separate the adhesive: Schritt 3, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement, Separate the adhesive: Schritt 3, Bild 3 von 3
    • During the next four steps, don't insert your opening pick deeper than 3 mm to prevent damaging internal components.
    • Optionally, you can measure and mark your opening pick 3 mm from the tip to help you visualize the length.
    • Slide the opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive.
    Frag FixBot
  4. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 4, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 4, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 4, Bild 3 von 3
    • Slide the pick around the top right corner and stop before the front camera.
    Frag FixBot
  5. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 5, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 5, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 5, Bild 3 von 3
    • Pull the opening pick out so only the tip is under the screen.
    • Slide the opening pick across the top edge of the screen until you're past the front camera.
    • Push your pick to its original depth before continuing.
    Frag FixBot
  6. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 6, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 6, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 6, Bild 3 von 3
    • Slide the opening pick around the top left corner and stop about two‑thirds down the left edge of the screen.
    • Don't slide the pick any farther, or you risk damaging the display cable.
    Frag FixBot
  7. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 7, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 7, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 7, Bild 3 von 3
    • Pull the opening pick out to a 2 mm depth and rotate the pick around the bottom left corner to separate the remaining adhesive.
    Frag FixBot
  8. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 8, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 8, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 8, Bild 3 von 3
    • Don't fully remove the screen yet, as it's still connected to the phone by a cable.
    • At this point, the screen should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the right edge of the screen and swing it over the left edge of the phone, like opening a book.
    • Prop up the screen with your suction handle or a clean, sturdy object.
    Frag FixBot
  9. Google Pixel 9 Pro Fold Outer Screen Replacement, Remove the display cable bracket screw: Schritt 9, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement, Remove the display cable bracket screw: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $31.41
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 2.2 mm‑long screw securing the display cable bracket.
    Frag FixBot
  10. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 10, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 10, Bild 2 von 2
    • Conductive tape secures the display cable bracket to the frame.
    • Use a spudger, or your fingers, to lift the display cable bracket enough to access the press connector underneath.
    Frag FixBot
  11. Google Pixel 9 Pro Fold Outer Screen Replacement, Disconnect the display cable: Schritt 11, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement, Disconnect the display cable: Schritt 11, Bild 2 von 2
    • Use the point of a spudger to pry up and disconnect the display cable press connector.
    Frag FixBot
  12. Google Pixel 9 Pro Fold Outer Screen Replacement, Remove the screen: Schritt 12, Bild 1 von 1
    • Lift the screen off the frame and remove it.
    Frag FixBot
  13. Google Pixel 9 Pro Fold Outer Screen Replacement, End of disassembly: Schritt 13, Bild 1 von 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    Frag FixBot
  14. Google Pixel 9 Pro Fold Outer Screen Replacement, Remove the old adhesive: Schritt 14, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement, Remove the old adhesive: Schritt 14, Bild 2 von 2
    • If your outer screen adhesive at the bottom left corner isn't sticky anymore, follow the next four steps to replace it. Otherwise, skip the next four steps.
    • Use a spudger, or your fingers, to remove the old bottom left outer screen adhesive.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
    Frag FixBot
  15. Google Pixel 9 Pro Fold Outer Screen Replacement, Compare your new adhesive: Schritt 15, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement, Compare your new adhesive: Schritt 15, Bild 2 von 2
    • Before removing any liners, check if the bottom left outer screen adhesive matches the frame.
    • The clear liner should face the frame.
    Frag FixBot
  16. Google Pixel 9 Pro Fold Outer Screen Replacement, Apply the new adhesive: Schritt 16, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement, Apply the new adhesive: Schritt 16, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement, Apply the new adhesive: Schritt 16, Bild 3 von 3
    • Peel the bottom left outer screen adhesive off its clear liner to expose the adhesive.
    • Put the adhesive into place on the frame.
    Frag FixBot
  17. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 17, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 17, Bild 2 von 2
    • Use the flat end of a spudger to press along the adhesive strip to adhere it to the frame.
    Frag FixBot
  18. Google Pixel 9 Pro Fold Outer Screen Replacement, Apply the new adhesive: Schritt 18, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement, Apply the new adhesive: Schritt 18, Bild 2 von 2
    • Before removing any liners, check if the perimeter outer screen adhesive matches the frame.
    Frag FixBot
  19. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 19, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 19, Bild 2 von 2
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded.
    Frag FixBot
  20. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 20, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 20, Bild 2 von 2
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
    Frag FixBot
  21. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 21, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 21, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 21, Bild 3 von 3
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
    Frag FixBot
  22. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 22, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 22, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 22, Bild 3 von 3
    • While peeling away the rest of the clear liner, slowly lay the rest of the adhesive over the perimeter of the phone.
    Frag FixBot
  23. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 23, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 23, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 23, Bild 3 von 3
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
    Frag FixBot
  24. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 24, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 24, Bild 2 von 2
    • Use the tip of a spudger to pry up the segmented tab on the bottom left corner of the large blue liner.
    Frag FixBot
  25. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 25, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 25, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 25, Bild 3 von 3
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it to the frame.
    Frag FixBot
  26. Google Pixel 9 Pro Fold Outer Screen Replacement, Reconnect the outer screen: Schritt 26, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement, Reconnect the outer screen: Schritt 26, Bild 2 von 2
    • Support the screen with your hand or prop it up on something sturdy.
    • Reconnect the outer screen cable press connector.
    Frag FixBot
  27. Google Pixel 9 Pro Fold Outer Screen Replacement, Reinstall the outer screen cable bracket: Schritt 27, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement, Reinstall the outer screen cable bracket: Schritt 27, Bild 2 von 2
    • Reinsert the outer screen cable bracket clip under the frame and align its screw hole.
    Frag FixBot
  28. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 28, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 28, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the 2.2 mm‑long screw securing the display cable bracket.
    Frag FixBot
  29. Google Pixel 9 Pro Fold Outer Screen Replacement, Expose the adhesive: Schritt 29, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement, Expose the adhesive: Schritt 29, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement, Expose the adhesive: Schritt 29, Bild 3 von 3
    • Remove the blue liner from the bottom left outer screen adhesive strip.
    • While holding the screen above the frame, separate one of the secondary liner's pull tabs at the bottom left corner.
    Frag FixBot
  30. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 30, Bild 1 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 30, Bild 2 von 3 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 30, Bild 3 von 3
    • Still holding the screen, peel off the secondary liner to expose the adhesive.
    Frag FixBot
  31. Google Pixel 9 Pro Fold Outer Screen Replacement, Secure the outer screen: Schritt 31, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement, Secure the outer screen: Schritt 31, Bild 2 von 2
    • Align the outer screen over the frame and press it into place.
    Frag FixBot
  32. Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 32, Bild 1 von 2 Google Pixel 9 Pro Fold Outer Screen Replacement: Schritt 32, Bild 2 von 2
    • Press along the perimeter of the outer screen to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
    Frag FixBot
Abschluss
Congratulations on completing your screen repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
6 weitere Personen haben diese Anleitung absolviert.
Alex Diaz-Kokaisl
239.519 Reputation
1.171 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.948 Anleitungen geschrieben
5 Kommentare zur Anleitung
Can I use a pixel 9 screen to replace outer pixel 9 fold screen??
james - Antwort Teilen
I can't find outer screen replacement part
note to others: the first time after installing, my phone did not power on many times over several hours and i was panicking. but i got it working, not sure which of it was the actual fix:
1. the screen cable should be plugged in quite snugly to the device. don't apply too much force, but apply enough that it latches on and isn't lose and moveable inside.
2. ensure your phone has charge.
3. hold the power button for longer than normal, about 15sec. then wait for 15sec before trying again.
4. try the other power up options - power+vol up, power+vol down for 15sec.
tarunk - Antwort Teilen
This guide was very helpful, and my repair went great!
I would like to make one additional note for others: the ring of adhesive that goes around the outside of the display may come as part of the new screen, and not a seperate part that needs to be placed on the phone first like the lower display adhesive does. If you are missing the adhesive, check the back of the new screen, it may be pre-applied to the new part.
If this is the case, after applying the lower display adhesive, remove the blue liner covering the adhesive, connect the display cable, tighten the screw to the bracket, then press the display into place.
Matthew T - Antwort Teilen
Süper anlatım teşekkürler
durmuş öztürk - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 40
Letzte 30 Tage: 166
Insgesamt: 3,844
