Zum Hauptinhalt wechseln
for this teardown you will need a loaf of bread which you can get at pretty much any store but be absolutely sure it is not pre sliced because then this guide does not apply
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
Dieser Teardown ist keine Reparaturanleitung. Um dein bread zu reparieren, verwende unsere Fehlerbehebungsseite.
    • with your utility Scissors carefully open the packaging and take out the loaf
    • take your bread knife and slice two pieces of bread off of the loaf
    • it is optional but adding butter to the bread will make it taste better
    • once the bread is torn down it cannot be repaired
LucWag1
477 Reputation
3 Anleitungen geschrieben
23 Kommentare zur Anleitung
thank u for the guide was very helpful
Rio - Antwort
Be careful it is not repairable after a tear down
LucWag1 -
Could have told me before hand? Now its broken 😭
NR26 -
Your guide is so helpful , long before my life was a completely mess because I couldn't even find even a single way to teardown a bread but after see your guide I am finally able to . Your help really saved my life , im really appreciated
thành thành - Antwort
I’m glad I could help
LucWag1 -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 43
Letzte 30 Tage: 358
Insgesamt: 5,047
