Zum Hauptinhalt wechseln
The Phantom 2 is DJI's revision to its original ready-to-fly quadcopter. The DJI Phantom, better known as the iPod of drones, is a quadcopter marketed primarily as an aerial photography platform for people with less R/C flight experience. Although the Phantom comes preassembled in a clean, white, plastic frame, the quadcopter contains similar hardware to other hobbyist drones, but in a more condensed package. Check out this guide for a detailed look at the propulsion, control, power, and video systems of this powerful tool.
Was du brauchst
Werkzeuge
Dieser Teardown ist keine Reparaturanleitung. Um dein DJI Phantom 2 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. DJI Phantom 2 Teardown, Brushless DC Motor: Schritt 1, Bild 1 von 3 DJI Phantom 2 Teardown, Brushless DC Motor: Schritt 1, Bild 2 von 3 DJI Phantom 2 Teardown, Brushless DC Motor: Schritt 1, Bild 3 von 3
    • Brushless AC Motor (DJIPV-06 DJI 2212)
    • Bottom - three color leds. Remove only some screws
  2. DJI Phantom 2 Teardown, ESC - Electronic Speed Control: Schritt 2, Bild 1 von 3 DJI Phantom 2 Teardown, ESC - Electronic Speed Control: Schritt 2, Bild 2 von 3 DJI Phantom 2 Teardown, ESC - Electronic Speed Control: Schritt 2, Bild 3 von 3
    • ESC - Electronic Speed Control
  3. DJI Phantom 2 Teardown, Remote Control and Main Control Circuit: Schritt 3, Bild 1 von 3 DJI Phantom 2 Teardown, Remote Control and Main Control Circuit: Schritt 3, Bild 2 von 3 DJI Phantom 2 Teardown, Remote Control and Main Control Circuit: Schritt 3, Bild 3 von 3
    • Remote Control and Main Control Circuit
  4. DJI Phantom 2 Teardown, Intelligent Battery: Schritt 4, Bild 1 von 3 DJI Phantom 2 Teardown, Intelligent Battery: Schritt 4, Bild 2 von 3 DJI Phantom 2 Teardown, Intelligent Battery: Schritt 4, Bild 3 von 3
    • Intelligent Battery - LIPO - 11,1V - 5200mAh
  5. DJI Phantom 2 Teardown, GPS circuit and cable: Schritt 5, Bild 1 von 1
    • GPS circuit and cable
  6. DJI Phantom 2 Teardown: Schritt 6, Bild 1 von 3 DJI Phantom 2 Teardown: Schritt 6, Bild 2 von 3 DJI Phantom 2 Teardown: Schritt 6, Bild 3 von 3
    • Bottom view : Zenmuse H3-3D Gimbal and FPV transmitter
    • FPV transmitter
    • Gimbal´s Brushless DC micro motor
3 Kommentare
Excellent job on documenting the tear down!
Ted Starcher - Antwort
Great job,Thank You, Massimo
Massi Ciccio - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 46
Insgesamt: 21,652
