Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese grundständige Anleitung beinhalten.
Schritt 2 übersetzen
Schritt 2
Use a pair of tweezers to carefully remove the charging port including its flex cable.
- | [* black] Use a pair of tweezers to carefully remove the charging port including its flex cable. |
+ | [* black] Use a pair of [product|IF145-020|tweezers] to carefully remove the charging port including its flex cable. |
[* icon_note] The charging port sits tightly in its recess. In case you have trouble removing it, use the flat end of a halberd spudger to pry it out. |
