Zum Hauptinhalt wechseln
iMac G5 20" Model A1145 Front Bezel Replacement
Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 15 Anleitungen, die diese grundständige Anleitung beinhalten.
Englisch
Deutsch
Schritt 4
iMac G5 20" Model A1145 Front Bezel Replacement: Schritt 0, Bild 1 von 3 iMac G5 20" Model A1145 Front Bezel Replacement: Schritt 0, Bild 2 von 3 iMac G5 20" Model A1145 Front Bezel Replacement: Schritt 0, Bild 3 von 3
  • Re-orient your iMac so it sits upright on the stand.
  • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
  • Push the card toward the top of the iMac to release the front bezel latch.
  • Pull the front bezel away from the rear case.
  • Repeat this process for the other side of the front bezel.
  • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
  • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
  • Alternatively, you can use a strong magnet by holding it to the front top left/right corner of the display. You will hear a snapping sound when the hatch is released.
Hier Übersetzung einfügen
