Zum Hauptinhalt wechseln
Motorola Moto E5 Play Display ersetzen
Englisch
Deutsch
Schritt 20
Motorola Moto E5 Play Screen Replacement: Schritt 0, Bild 1 von 3 Motorola Moto E5 Play Screen Replacement: Schritt 0, Bild 2 von 3 Motorola Moto E5 Play Screen Replacement: Schritt 0, Bild 3 von 3
  • Use the point of a spudger to pry up a corner of the black battery mat.
  • Use your fingers to slowly peel the battery mat from the frame.
  • There is a flex cable underneath the mat, and portions may stick to the mat as you peel it off. If that happens, carefully loosen the cable from the mat as you peel.
Heble die Ecke der Akkuunterlage mit der Spitze eines Spudgers nach oben.
Ziehe die Unterlage mit deinen Fingern vom Rahmen.
[* black] Use the point of a spudger to pry up a corner of the black battery mat.
-[* black] Use your fingers to peel the battery mat from the frame.
+[* black] Use your fingers to slowly peel the battery mat from the frame.
+ [* icon_note] There is a flex cable underneath the mat, and portions may stick to the mat as you peel it off. If that happens, carefully loosen the cable from the mat as you peel.
