Zum Hauptinhalt wechseln
How to Replace a Ceiling Fan Lighting Circuit Power-Limiting Device
Englisch
Koreanisch
Schritt 6
How to Replace a Ceiling Fan Lighting Circuit Power-Limiting Device: Schritt 0, Bild 1 von 3 How to Replace a Ceiling Fan Lighting Circuit Power-Limiting Device: Schritt 0, Bild 2 von 3 How to Replace a Ceiling Fan Lighting Circuit Power-Limiting Device: Schritt 0, Bild 3 von 3
  • To remove the power-limiting device (Part No. 98480-02) from the circuit:
  • Loosen and remove the twist-on wire connectors.
  • Disconnect the terminal connectors.
  • If you are removing the power-limiting device, proceed to Step 7.
  • If you are replacing the power-limiting device, install the new power-limiting device in the same configuration as the old power-limiting device, and skip to Step 9.
Hier Übersetzung einfügen
