Zum Hauptinhalt wechseln
전면 패널 어셈블리 분리
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 15 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 7 übersetzen
Schritt 7
Front Panel Assembly Removal, Remove the front panel assembly: Schritt 0, Bild 1 von 3 Front Panel Assembly Removal, Remove the front panel assembly: Schritt 0, Bild 2 von 3 Front Panel Assembly Removal, Remove the front panel assembly: Schritt 0, Bild 3 von 3
  • Remove the front panel assembly.
  • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
  • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
  • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
  • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
  • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
전면 패널 어셈블리를 분리하세요.
여는 픽을 사용하여 전면 패널 어셈블리를 프레임에 연결하고 있을 수 있는 나머지 접착제를 잘라내세요.
새 디스플레이에서 “고스트” 또는 “팬텀” 터치 입력 문제가 발생하는 경우 패널 뒷면의 강조 표시된 부분에 Kapton(폴리이미드) 테이프와 같은 매우 얇은 절연 테이프를 덧대면 이 문제를 해결할 수 있습니다. iFixit 교체용 디지타이저에는 적절한 절연재가 함께 제공되므로 테이프를 덧댈 필요가 없습니다.
적절한 절연 처리 없이는 디지타이저의 이러한 부분이 다른 부품에 접지되어 터치 입력 오작동을 일으킬 수 있습니다.
절연재는 육안으로 보이지 않으며 많은 iPad에서 볼 수 있는 폼 방진 스트립과는 다릅니다.
디스플레이를 재조립할 때는 디스플레이를 설치하기 전에 iPad에 남아 있는 접착제를 제거하고 고농도 이소프로필 알코올(90% 이상)과 보풀이 없는 천으로 접착 부위를 닦아주세요. 이렇게 하면 iPad가 새 접착제를 사용할 수 있도록 준비가 되며 제대로 접착될 수 있습니다.
iPad의 기능을 테스트하고 디스플레이 접착제 적용 안내서를 사용하여 디스플레이 뒷면에 미리 자른 접착 스트립을 설치한 후 봉인하세요.
