Zum Hauptinhalt wechseln
Samsung Galaxy S6 Midframe Assembly Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 13 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 2
Samsung Galaxy S6 Midframe Assembly Replacement: Schritt 0, Bild 1 von 3 Samsung Galaxy S6 Midframe Assembly Replacement: Schritt 0, Bild 2 von 3 Samsung Galaxy S6 Midframe Assembly Replacement: Schritt 0, Bild 3 von 3
  • Before you perform this step, make sure you've ejected the SIM card tray.
  • Firmly grasp the edge of the midframe assembly.
  • Lift up on the midframe assembly while pushing down on the battery to separate the midframe assembly from the rest of the phone.
  • While lifting the midframe, be careful to avoid snagging it on the audio jack or charging port.
  • Once the midframe is partially seperated, carefully run an opening pick around the edges of the rest of the phone to separate the top of the midframe.
  • Be careful not to accidentally insert the opening pick between the glass and display.
  • To avoid damage to the headphone jack, remove the top of the midframe first, then push the midframe downwards to disengage it from the headphone jack.
  • You may need to heat and apply an iOpener to the edges of the display to soften the display adhesive if midframe separation is difficult.
Hier Übersetzung einfügen
