Zum Hauptinhalt wechseln
Samsung Galaxy S6 Edge Battery Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Koreanisch
Schritt 2 übersetzen
Schritt 2
Samsung Galaxy S6 Edge Battery Replacement: Schritt 0, Bild 1 von 2 Samsung Galaxy S6 Edge Battery Replacement: Schritt 0, Bild 2 von 2
  • Twist the opening pick to fully dislodge the battery and remove it.
  • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
  • To install a new battery and ensure that is is properly aligned:
  • Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  • Lay the replacement battery in place, but do not apply adhesive yet. Resume re-assembly until the motherboard is in place (STEP 18).
  • Apply new pre-cut adhesive or double-sided tape onto the phone frame, around the perimeter of the battery compartment, but not in the rectangular cutout in the center (which is actually the back side of the display).
  • Temporarily connect the battery connector to the motherboard to ensure proper battery alignment.
  • Press the battery firmly into place for 5-10 seconds. Disconnect the battery and resume re-assembly.
Hier Übersetzung einfügen
