Zum Hauptinhalt wechseln
ANKER SoundCore Speaker Replacement
Cory Troxell
Cory Troxell und 3 weitere Mitwirkende
Zuletzt aktualisiert am May 5, 2020
8 - 10 Minuten
Mittel
This is a step-be-step guide on how to replace the ANKER Soundcore speakers.
Before attempting to replace anything, it is recommended that you look at this device’s troubleshooting guide.
Faulty speakers are often the cause of poor sound quality, but are not always the problem. Check the troubleshooting guide before, for any other possible solutions to poor sound quality.
Was du brauchst
Werkzeuge
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Mehr anzeigen …
  1. ANKER SoundCore Speaker Replacement, Speaker: Schritt 1, Bild 1 von 3 ANKER SoundCore Speaker Replacement, Speaker: Schritt 1, Bild 2 von 3 ANKER SoundCore Speaker Replacement, Speaker: Schritt 1, Bild 3 von 3
    • Use a iFixit plastic opening tool to pry off the screen.
    • Remove the screen from the device.
  2. ANKER SoundCore Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the 10mm Philips #0 screws from speaker mount.
  3. ANKER SoundCore Speaker Replacement: Schritt 3, Bild 1 von 3 ANKER SoundCore Speaker Replacement: Schritt 3, Bild 2 von 3 ANKER SoundCore Speaker Replacement: Schritt 3, Bild 3 von 3
    • Use a spudger tool to remove speaker mount.
    • Ensure all wires are still properly attached in device.
  4. ANKER SoundCore Speaker Replacement: Schritt 4, Bild 1 von 3 ANKER SoundCore Speaker Replacement: Schritt 4, Bild 2 von 3 ANKER SoundCore Speaker Replacement: Schritt 4, Bild 3 von 3
    • Remove the 8mm Philips #0 screws holding speakers in place.
  5. ANKER SoundCore Speaker Replacement: Schritt 5, Bild 1 von 3 ANKER SoundCore Speaker Replacement: Schritt 5, Bild 2 von 3 ANKER SoundCore Speaker Replacement: Schritt 5, Bild 3 von 3
    • Pull out the speakers.
  6. ANKER SoundCore Speaker Replacement: Schritt 6, Bild 1 von 2 ANKER SoundCore Speaker Replacement: Schritt 6, Bild 2 von 2
    • Desolder the speaker wires.
    • Remove both of the speakers from the circuit board.
    • For help soldering and desoldering, follow this guide.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S22-G1, Regan Winter 2020 Mitglied von Cal Poly, Team S22-G1, Regan Winter 2020
CPSU-REGAN-W20S22G1
5 Mitglieder
7 Anleitungen geschrieben
4 Kommentare
What speaker do you replace them with?
tom mason - Antwort
I would like to buy some parts of recording of this items how do I get from y’all is there any phone number Contac anything UK
Octavio Rodrigues - Antwort
Where I can find the speaker replacement part or part number?
I tried numbers back but not the same shape!
Jaider Villa - Antwort
Where can I find replacement speakers as mine are damaged, thanks.
Ian - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 23
Letzte 30 Tage: 72
Insgesamt: 9,500
