Zum Hauptinhalt wechseln
ASUS ROG Zephyrus M15GU205L Display Cable Replacement
Yahir Donis
Yahir Donis und 2 weitere Mitwirkende
Zuletzt aktualisiert am January 20, 2025
1 Stunde
Mittel
Action Shots
Aufzählungszeichen!
Unklarer Text
Benötigt Mehr Bilder
If your screen is glitching or the screen goes in and out, it might be a loose display connector. Use this guide if you need to check to see if your display connector is loose.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ASUS ROG Zephyrus M15GU205L Display Cable Replacement, Battery: Schritt 1, Bild 1 von 2 ASUS ROG Zephyrus M15GU205L Display Cable Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
  2. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: Schritt 2, Bild 1 von 2 ASUS ROG Zephyrus M15GU205L Display Cable Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you separate the laptop cover from the side and run the tool along the edge of the cover to open it.
    • Be careful not to damage the cover when removing it from the laptop.
  3. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: Schritt 3, Bild 1 von 1
    • Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
  4. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: Schritt 4, Bild 1 von 2 ASUS ROG Zephyrus M15GU205L Display Cable Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the 8-pin battery that secures the battery to the motherboard.
    • Use the nylon tipped reverse tweezers to squeeze the edges, then pull out the connector.
  5. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery from the computer.
  6. ASUS ROG Zephyrus M15GU205L Display Cable Replacement, Display Cable: Schritt 6, Bild 1 von 1
    • Once the back has been removed, locate this connection cable.
    • Check to see if the connector is in the pin slot; if not, locate the connector.
  7. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: Schritt 7, Bild 1 von 1
    • If the connection is loose, connect the pins into the slot.
    • Once the connector is connected, do these steps in reverse.
Abschluss
Yahir Donis
339 Reputation
2 Anleitungen geschrieben
Gateway, Team 69-69, Gonzalez Fall 2023 Mitglied von Gateway, Team 69-69, Gonzalez Fall 2023
GCC-GONZALEZ-F23S69G69
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 22
Letzte 30 Tage: 81
Insgesamt: 591
