Zum Hauptinhalt wechseln
Acer Chromebook C710-2833 Fan Replacement
Nicholas Latorre
Nicholas Latorre und 4 weitere Mitwirkende
Zuletzt aktualisiert am March 7, 2024
5 - 7 Minuten
Mittel
In this replacement guide, you will learn how to safely remove and install a cooling fan.
  1. Acer Chromebook C710-2833 Fan Replacement, Fan: Schritt 1, Bild 1 von 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Fan Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C710-2833 Fan Replacement: Schritt 2, Bild 2 von 2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 Fan Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook C710-2833 Fan Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 Fan Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook C710-2833 Fan Replacement: Schritt 4, Bild 2 von 2
    • Locate the two 6 mm Phillips #00 screws on the fan port.
    • Unscrew the two screws and place them aside for now.
  5. Acer Chromebook C710-2833 Fan Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook C710-2833 Fan Replacement: Schritt 5, Bild 2 von 2
    • Carefully remove the fan from its port. You may need to use a little force as there will be an adhesive on the right side of the fan keeping it in place.
    • Locate the Molex cable connecting the fan to its port in the top left corner.
    • Disconnect the cable.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team S1-G6, Nance Fall 2017 Mitglied von USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 938
