Asus G750JW-BBI7N05 RAM Replacement
Einleitung
Zu Schritt 1 der AnleitungFaulty or failing RAM can cause a variety of issues, from random crashing to a total loss of power. This guide will walk you through locating and replacing your laptop's RAM.
Was du brauchst
Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
Lift up the rubber stopper on the backplate to expose one Phillips screw. Unscrew it until it becomes loose.
Remove each RAM module one at a time by sliding them downward out of their slots.
Eine weitere Person hat diese Anleitung absolviert.
