Zum Hauptinhalt wechseln
Asus G75VW-BHI7N07 Audio Jack  Replacement
Joy
Joy und 2 weitere Mitwirkende
Zuletzt aktualisiert am January 5, 2018
25 Minuten
Mittel
Benötigt Bessere Bilder
The Audio Jack can wear out over time or stop working completely. This guide will show you how to remove the Audio Jack on the side of the device.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: Schritt 1, Bild 1 von 3 Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: Schritt 1, Bild 2 von 3 Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: Schritt 1, Bild 3 von 3
    • Remove the 5 (9 mm screws) around the outside edges of the back cover with the PH1 Phillips-head screwdriver.
    • Lift off the back cover using the opening tool.
  2. Asus G75VW-BHI7N07 Audio Jack  Replacement: Schritt 2, Bild 1 von 3 Asus G75VW-BHI7N07 Audio Jack  Replacement: Schritt 2, Bild 2 von 3 Asus G75VW-BHI7N07 Audio Jack  Replacement: Schritt 2, Bild 3 von 3
    • Remove the 10 (9 mm) screws marked 'A' using the PH1 Phillips-head screwdriver.
    • Remove the battery by pressing the slide release button.
    • Remove 2 more (9 mm) 'A' marked screws within the battery compartment using the PH1 Phillips-head screwdriver.
  3. Asus G75VW-BHI7N07 Audio Jack  Replacement: Schritt 3, Bild 1 von 2 Asus G75VW-BHI7N07 Audio Jack  Replacement: Schritt 3, Bild 2 von 2
    • Remove the cover for the disc drive with the opening tool.
    • Remove the 6 (4 mm) 'B' marked screws with the PH1 Phillips-head screwdriver. (3 screws are in the battery compartment and 3 are under the disc drive cover)
  4. Asus G75VW-BHI7N07 Audio Jack  Replacement: Schritt 4, Bild 1 von 2 Asus G75VW-BHI7N07 Audio Jack  Replacement: Schritt 4, Bild 2 von 2
    • Pry open the keypad platform with the opening tool.
    • You will need to lift the keypad platform with your hands to get to the laptop's internal systems.
  5. Asus G75VW-BHI7N07 Audio Jack  Replacement: Schritt 5, Bild 1 von 3 Asus G75VW-BHI7N07 Audio Jack  Replacement: Schritt 5, Bild 2 von 3 Asus G75VW-BHI7N07 Audio Jack  Replacement: Schritt 5, Bild 3 von 3
    • Take out 1 (5mm) screw, using the J0 Phillips head screwdriver.
    • Use the opening tool to remove the audio-electrical board.
    • Lift out with your hands.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Joy
437 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 681
