Zum Hauptinhalt wechseln
Asus ROG G752V Motherboard Replacement
Jeong
Jeong und 6 weitere Mitwirkende
Zuletzt aktualisiert am April 24, 2023
4 Stunden
Schwierig
Use this guide if you need to replace the motherboard in your Asus ROG G752V.
The motherboard acts as a single platform to connect all of the parts of a computer together. It serves as the computer's nervous system.
Reasons to replace your motherboard:
  • Physical damage to the board
  • If peripherals work intermittently, try using different peripherals in different ports to see if it is a bad port, bad peripheral, or bad motherboard
  • Computer does not post (No bios on startup)
  • Upgrades
Before beginning, make sure to power off your computer. Disconnect it from any external power source. Remove dust build-up with a dust blower.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Asus ROG G752V Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Asus ROG G752V Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Make sure you disconnect the charger before starting this guide.
    • Pick out all 11 rubber plugs off of the back cover with a pair of tweezers.
  2. Asus ROG G752V Motherboard Replacement: Schritt 2, Bild 1 von 2 Asus ROG G752V Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Using the Phillips #0 screwdriver, unscrew all twelve 5.2 mm screws on the back of the laptop.
    • There is one 5.2 mm screw under the rubber plug in the middle.
  3. Asus ROG G752V Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Pull up the rubber seal and the service cover will come off.
  4. Asus ROG G752V Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the six 5.2 mm screws under the service cover.
  5. Asus ROG G752V Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Using your hands, pull the optical drive out.
  6. Asus ROG G752V Motherboard Replacement: Schritt 6, Bild 1 von 2 Asus ROG G752V Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Use the iFixit Opening Tool to pry apart the back panel from the main body of the laptop.
    • Start from the front side of the laptop and then continue to the side for easier access.
  7. Asus ROG G752V Motherboard Replacement: Schritt 7, Bild 1 von 2 Asus ROG G752V Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the hinge on the back of the laptop cover using the iFixit Opening Tool. The piece should pop off.
    • Be gentle with the cover because there is a speaker wire attached to it.
  8. Asus ROG G752V Motherboard Replacement: Schritt 8, Bild 1 von 2 Asus ROG G752V Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the speaker wire.
  9. Asus ROG G752V Motherboard Replacement: Schritt 9, Bild 1 von 2 Asus ROG G752V Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Slowly pull out the keyboard while lifting it about an inch.
    • There are cables attached to the keyboard and motherboard. DO NOT lift it more than 2 inches above the laptop.
  10. Asus ROG G752V Motherboard Replacement: Schritt 10, Bild 1 von 3 Asus ROG G752V Motherboard Replacement: Schritt 10, Bild 2 von 3 Asus ROG G752V Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Using an ESD safe tool, detach all 3 ribbon cables securing the keyboard to the laptop.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
  11. Asus ROG G752V Motherboard Replacement: Schritt 11, Bild 1 von 2 Asus ROG G752V Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Once the cables are detached, lift the keyboard about 2 inches up and remove it from the rest of the body.
    • Make sure that the screen is open like the photo. This will ensure that none your laptop components will not be bent.
  12. Asus ROG G752V Motherboard Replacement: Schritt 12, Bild 1 von 3 Asus ROG G752V Motherboard Replacement: Schritt 12, Bild 2 von 3 Asus ROG G752V Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the left of the socket.
    • Pull parallel to the motherboard, not straight up.
  13. Asus ROG G752V Motherboard Replacement: Schritt 13, Bild 1 von 3 Asus ROG G752V Motherboard Replacement: Schritt 13, Bild 2 von 3 Asus ROG G752V Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Remove two 5.8 mm screws holding the screen and the laptop located at the hinge.
    • This will unlatch the screen from the laptop entirely.
    • Remove the screen.
  14. Asus ROG G752V Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Remove the four 5.8 mm screws securing the battery to the laptop.
  15. Asus ROG G752V Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Use your hands to remove the battery.
    • If you're having trouble, push down on the black plastic on the screen side of the battery. This should release the battery.
  16. Asus ROG G752V Motherboard Replacement, Wireless Card: Schritt 16, Bild 1 von 3 Asus ROG G752V Motherboard Replacement, Wireless Card: Schritt 16, Bild 2 von 3 Asus ROG G752V Motherboard Replacement, Wireless Card: Schritt 16, Bild 3 von 3
    • Unscrew one 3mm Philips #00 screw on the wireless card.
  17. Asus ROG G752V Motherboard Replacement: Schritt 17, Bild 1 von 2 Asus ROG G752V Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Using your hands, unlatch the wireless card by pulling it out toward the screen.
    • Gently wiggle the card and pull it out of the motherboard.
  18. Asus ROG G752V Motherboard Replacement, Fan: Schritt 18, Bild 1 von 2 Asus ROG G752V Motherboard Replacement, Fan: Schritt 18, Bild 2 von 2
    • Unplug the fan-motherboard connection cable.
  19. Asus ROG G752V Motherboard Replacement: Schritt 19, Bild 1 von 3 Asus ROG G752V Motherboard Replacement: Schritt 19, Bild 2 von 3 Asus ROG G752V Motherboard Replacement: Schritt 19, Bild 3 von 3
    • Unscrew and remove the three 5.8mm screws on the small circuit board to the right of the right side fan with a Phillips #00 screwdriver.
    • Lift up the small circuit board covering the fan and put it aside.
  20. Asus ROG G752V Motherboard Replacement: Schritt 20, Bild 1 von 2 Asus ROG G752V Motherboard Replacement: Schritt 20, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the three 5.2 mm screws that connect the fan to the motherboard.
  21. Asus ROG G752V Motherboard Replacement: Schritt 21, Bild 1 von 1
    • With your hands, slowly and carefully lift up the right side fan.
  22. Asus ROG G752V Motherboard Replacement: Schritt 22, Bild 1 von 2 Asus ROG G752V Motherboard Replacement: Schritt 22, Bild 2 von 2
    • Carefully unlatch the left side fan cable from the motherboard.
  23. Asus ROG G752V Motherboard Replacement: Schritt 23, Bild 1 von 3 Asus ROG G752V Motherboard Replacement: Schritt 23, Bild 2 von 3 Asus ROG G752V Motherboard Replacement: Schritt 23, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove the two 5.8mm screws that connect the left fan to the motherboard.
  24. Asus ROG G752V Motherboard Replacement: Schritt 24, Bild 1 von 2 Asus ROG G752V Motherboard Replacement: Schritt 24, Bild 2 von 2
    • With your hands, carefully lift the left fan and unlatch the fan from the motherboard.
  25. Asus ROG G752V Motherboard Replacement, Motherboard: Schritt 25, Bild 1 von 2 Asus ROG G752V Motherboard Replacement, Motherboard: Schritt 25, Bild 2 von 2
    • Using your hand, detach the Woofer Cable.
  26. Asus ROG G752V Motherboard Replacement: Schritt 26, Bild 1 von 2 Asus ROG G752V Motherboard Replacement: Schritt 26, Bild 2 von 2
    • Using your hand, detach the Speaker cable.
  27. Asus ROG G752V Motherboard Replacement: Schritt 27, Bild 1 von 3 Asus ROG G752V Motherboard Replacement: Schritt 27, Bild 2 von 3 Asus ROG G752V Motherboard Replacement: Schritt 27, Bild 3 von 3
    • Using an ESD safe tool, first unlatch the ZIF connector clasp and then pull the cord disconnecting the SD card reader.
  28. Asus ROG G752V Motherboard Replacement: Schritt 28, Bild 1 von 2 Asus ROG G752V Motherboard Replacement: Schritt 28, Bild 2 von 2
    • Unscrew eighteen 5.8 mm screws from the motherboard with a Phillips #00 screwdriver.
  29. Asus ROG G752V Motherboard Replacement: Schritt 29, Bild 1 von 2 Asus ROG G752V Motherboard Replacement: Schritt 29, Bild 2 von 2
    • Using your hands, unlatch the motherboard by lifting it up directly above the laptop.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
This guide is full of mistakes, please redo it !!! not good at all.
The wifi card can stay on the mobo, and there is not always teh same screw size... Some screws can stay on the board or the place shown does not exists.... show the routing of the cables also, behind the screen....
Leo Etcheverry - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 18
Letzte 30 Tage: 65
Insgesamt: 4,928
