Zum Hauptinhalt wechseln
Asus ROG GL551J Hard Drive Replacement
Thien Vu
Thien Vu und 2 weitere Mitwirkende
Zuletzt aktualisiert am November 16, 2022
2 Minuten
Mittel
Fehlende Angaben
Use this guide to remove replace the hard drive in your Asus ROG GL551J, which can be completed in fewer than 3 steps.
Was du brauchst
Komplettpaket für die Reparatur
Diese Kits enthalten alle Ersatzteile und Werkzeuge, die für diese Anleitung benötigt werden.
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Asus ROG GL551J Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery out.
  4. Asus ROG GL551J Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Asus ROG GL551J Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • With laptop upside-down, locate and unscrew the two screws on the panel with the vents.
    • Slide the panel out and lift up to remove.
  5. Asus ROG GL551J Hard Drive Replacement: Schritt 5, Bild 1 von 2 Asus ROG GL551J Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • The hard drive is the metal rectangle with the two soft padding bars attached to it.
    • Locate and remove the 4 screws holding the hard drive down at each corner using a PH000 Philips head.
  6. Asus ROG GL551J Hard Drive Replacement: Schritt 6, Bild 1 von 2 Asus ROG GL551J Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Locate the black plastic tab attached to the bottom of the hard drive and pull it straight outwards.
    • Failure to correctly disconnect the hard drive before pulling it up and out can damage the connectors.
    • Once the hard drive detaches from the connector, lift the hard drive up and out.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Thien Vu
412 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 5-4, Lacy Spring 2017 Mitglied von USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 31
Insgesamt: 4,674
