Zum Hauptinhalt wechseln
Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement
John Robert Miller
John Robert Miller und 3 weitere Mitwirkende
Zuletzt aktualisiert am December 10, 2020
25 Minuten
Mittel
Umwege erhöhen die Ortskenntnis
Should the trackpad in your Asus ROG Strix GL702VM-BHI7N09 gaming laptop fail, this replacement guide is just for you! The trackpad is required for navigation and use of the computer.
Note that although this guide has you remove the motherboard and display before removing the trackpad, this is not absolutely necessary to replace the trackpad. Instead you can disconnect the cables as shown in Step 14 to remove the trackpad with the rest of the computer still intact.
Was du brauchst
Werkzeuge
Mehr anzeigen …
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Back Panel: Schritt 1, Bild 1 von 2 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 2, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 2, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 2, Bild 3 von 3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Battery: Schritt 3, Bild 1 von 1
    • Unplug the battery from the motherboard.
  4. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 4, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 4, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the 3.8 mm Phillips #1 screw on the top right hand corner of the battery.
    • Lift battery from laptop frame.
  5. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the four 4 mm screws holding the hard drive.
  6. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 6, Bild 1 von 1
    • Pull the hard drive directly away from the fan just above it.
    • The connecting pins should slide out easily, but you might have to move the hard drive around a bit to loosen the pins.
  7. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Fan: Schritt 7, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the four indicated 4 mm screws that hold the black fan and the silver one adjacent to it.
  8. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 8, Bild 1 von 1
    • The smaller black fan must be removed before the larger gray fan on the right can be taken out.
    • To remove the black fan, pull gently on the connecting cables outlined.
  9. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 9, Bild 1 von 1
    • Unplug the white connector by gently pulling the cables.
    • Lift off the gray fan.
  10. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 10, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the two indicated 4 mm screws from the other gray fan.
  11. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 11, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 11, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 11, Bild 3 von 3
    • Unplug the white connector by gently pulling it towards the center of the computer.
    • Lift the fan out of the body of the laptop to remove it.
  12. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Motherboard: Schritt 12, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Motherboard: Schritt 12, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Motherboard: Schritt 12, Bild 3 von 3
    • Disconnect the speakers connectors located in each of the bottom corners.
    • Gently pull the wire up from the motherboard.
    • Once the wire is disconnected, pull the speaker out.
  13. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 13, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 13, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 13, Bild 3 von 3
    • Gently lift the graphics card from the motherboard.
  14. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 14, Bild 1 von 2 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 14, Bild 2 von 2
    • Use reverse pliers to detach ribbon connectors from the motherboard.
  15. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 15, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 15, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 15, Bild 3 von 3
    • Remove each of the 4.7 mm Phillips #1 screws marked by a white arrow on the motherboard.
    • Remove the 6.7 mm Phillips #1 screws from the metal latches on the hinge-side corners.
    • The 4.7 mm Phillips #1 screw on the far left of the motherboard is covered by the black connecting wire in Step 5.
  16. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 16, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 16, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 16, Bild 3 von 3
    • Gently pull on black connecting wire to disconnect the monitor screen from the motherboard.
    • This will uncover the far left 4.7 mm Phillips #1 screw.
  17. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 17, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 17, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 17, Bild 3 von 3
    • Lift the metal latches on both sides.
    • This can be easily done by opening the laptop after the metal latch screws have been removed.
  18. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement: Schritt 18, Bild 1 von 1
    • Remove the motherboard from the laptop frame.
    • You will need to pull the motherboard to the side as well as lifting it to free its various ports from the sides of the laptop case.
    • There is adhesive attaching the final ribbon connector to the bottom of the motherboard. This will need to be removed.
  19. Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Trackpad: Schritt 19, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Trackpad: Schritt 19, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Trackpad Replacement, Trackpad: Schritt 19, Bild 3 von 3
    • Ensure the ribbon cables on the trackpad are disconnected.
    • Using a Phillips #1 screwdriver, remove the three 4mm retaining screws.
    • Gently lift and slide the track pad out of the mount.
    • It may help to lift the trackpad from the underside near the keyboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 733
