Zum Hauptinhalt wechseln
Asus ROG Strix GL702VS Back Cover Replacement
Ryan McCabe
Ryan McCabe und 5 weitere Mitwirkende
Zuletzt aktualisiert am August 26, 2023
1 - 10 Minuten
Leicht
This simple guide will be used in almost every step involved in repairing the computer. You will need to remove the bottom cover to access all of the components of the computer. This should be done in a contained well-lit setting since the small screws may be easy to lose in low light settings.
Was du brauchst
Werkzeuge
  1. Asus ROG Strix GL702VS Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Flip the computer so the bottom of the laptop is facing up.
  2. Asus ROG Strix GL702VS Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
  3. Asus ROG Strix GL702VS Back Cover Replacement: Schritt 3, Bild 1 von 2 Asus ROG Strix GL702VS Back Cover Replacement: Schritt 3, Bild 2 von 2
    • Use a Jimmy to carefully free each side of the bottom casing.
  4. Asus ROG Strix GL702VS Back Cover Replacement: Schritt 4, Bild 1 von 1
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 11
Insgesamt: 1,479
