Zum Hauptinhalt wechseln
Asus ROG Strix GL702VS Fan Replacement
Conor H Allen
Conor H Allen und 5 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
15 Minuten - 1 Stunde
Mittel
This is a step by step guide for the removal of the Asus ROG Strix GL702VS cooling fans for replacement or repair. If you are experiencing overheating problems or loud fan noises and grinding, follow these steps to remove the fans for replacement, repair, or cleaning.
Was du brauchst
Werkzeuge
  1. Asus ROG Strix GL702VS Fan Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Flip the computer so the bottom of the laptop is facing up.
  2. Asus ROG Strix GL702VS Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
  3. Asus ROG Strix GL702VS Fan Replacement: Schritt 3, Bild 1 von 2 Asus ROG Strix GL702VS Fan Replacement: Schritt 3, Bild 2 von 2
    • Use a Jimmy to carefully free each side of the bottom casing.
  4. Asus ROG Strix GL702VS Fan Replacement: Schritt 4, Bild 1 von 1
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
  5. Asus ROG Strix GL702VS Fan Replacement, Cooling Fans: Schritt 5, Bild 1 von 3 Asus ROG Strix GL702VS Fan Replacement, Cooling Fans: Schritt 5, Bild 2 von 3 Asus ROG Strix GL702VS Fan Replacement, Cooling Fans: Schritt 5, Bild 3 von 3
    • Remove the four 4.8mm JIS #0 screws (two on each fan).
  6. Asus ROG Strix GL702VS Fan Replacement: Schritt 6, Bild 1 von 3 Asus ROG Strix GL702VS Fan Replacement: Schritt 6, Bild 2 von 3 Asus ROG Strix GL702VS Fan Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Remove the fan's connector on the motherboard using a pair of tweezers.
    • Be gentle, as the small clips and wires can be easily damaged.
  7. Asus ROG Strix GL702VS Fan Replacement: Schritt 7, Bild 1 von 2 Asus ROG Strix GL702VS Fan Replacement: Schritt 7, Bild 2 von 2
    • Gently lift each fan up and out of position.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 3,034
