Zum Hauptinhalt wechseln
Canon PowerShot A80 LCD Screen Replacement
konrad
konrad und 15 weitere Mitwirkende
Zuletzt aktualisiert am January 9, 2025
20 - 40 Minuten
Mittel
Action Shots
Is your Canon PowerShot A80’s LCD screen blurry, cracked, or failing to display images? This guide walks you through replacing the faulty screen so your camera can function like new. A broken LCD makes it tough to focus on your subjects or navigate settings.
Important: Before starting, turn off the camera and remove the battery to avoid electric shock or damage. If you're unsure whether the screen is the issue, visit our troubleshooting page for more help.
Was du brauchst
Werkzeuge
  1. Canon PowerShot A80 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the two 2.9 mm screws on the side of the LCD screen.
  2. Canon PowerShot A80 LCD Screen Replacement: Schritt 2, Bild 1 von 2 Canon PowerShot A80 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the 2.9 mm screws on the other side of the screen to separate the front and back covers.
    • To access the second screw, rotate the screen 90° so that it faces upwards.
  3. Canon PowerShot A80 LCD Screen Replacement: Schritt 3, Bild 1 von 3 Canon PowerShot A80 LCD Screen Replacement: Schritt 3, Bild 2 von 3 Canon PowerShot A80 LCD Screen Replacement: Schritt 3, Bild 3 von 3
    • Gently remove the front and back covers from the screen.
    • Peel back the plastic circuit cover.
  4. Canon PowerShot A80 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Pull the screen away from the base.
    • This will take some force, but remember to handle with care.
    • If a small metal piece between the screen cover and the screen falls out during repair, replace it with the rounded corners facing away from the screen during reassembly.
  5. Canon PowerShot A80 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Unplug the ribbon cable connected to the circuit board latch.
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
4 weitere Personen haben diese Anleitung absolviert.
konrad
220 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 7-31, Regan Winter 2011 Mitglied von Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
MY screen is dark after touched water, do I need to change this screen? Where can I buy this screen? How much?
Thank you for the guidance.
jennifer
yu123xi@yahoo.com
yu123xi - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 20
Letzte 30 Tage: 45
Insgesamt: 4,364
