Einleitung
If you have an issue with your speaker as stated in our troubleshooting page ( HTC One M7 Troubleshooting ) then this guide is for you.
Ersatzteile
Keine Ersatzteile angegeben.
Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
Lift the camera from the bottom of the motherboard.
Remove the #000 screws around the speaker that are located at the bottom of the frame.
Lift the speaker out of the frame.
16 weitere Nutzer haben diese Anleitung absolviert.
