Zum Hauptinhalt wechseln
Hoover Power Path Deluxe FH50951 Nozzle Replacement
Jon-Erik Hylle
Jon-Erik Hylle und eine weitere beteiligte Person
Zuletzt aktualisiert am December 27, 2024
15 - 25 Minuten
Mittel
If your Hoover Power Path Deluxe FH50951 is having suction issues such as water and debris not being sucked into the dirty water tank, you can replace the nozzle using this guide.
The nozzle vacuums debris dislodged by the brushes and water dispenser. Before using this guide, if you are experiencing low or no suction, work through these troubleshooting guides in order to isolate the nozzle as the culprit. Cracks, deformation, punctures, or severe blockages are reasons the nozzle needs to be replaced.
Before replacing the nozzle, make sure the device is turned off, unplugged, and the dirty water tank is removed.
Was du brauchst
Werkzeuge
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Hoover Power Path Deluxe FH50951 Nozzle Replacement, Brush Roll: Schritt 1, Bild 1 von 3 Hoover Power Path Deluxe FH50951 Nozzle Replacement, Brush Roll: Schritt 1, Bild 2 von 3 Hoover Power Path Deluxe FH50951 Nozzle Replacement, Brush Roll: Schritt 1, Bild 3 von 3
    • Remove the four 18.6 mm screws labeled 1-4 using a Phillips #1 screwdriver.
    • Remove the piece that was being held down by those screws.
  2. Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 2, Bild 1 von 3 Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 2, Bild 2 von 3 Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 18.6 mm screws with arrows listing 5-8 using a Phillips #1 screwdriver.
    • Remove the wheel assembly on the left side of the vacuum.
    • You may need a longer Phillips #1 screwdriver for screw #7.
  3. Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 3, Bild 1 von 1
    • Lift up the belt to give enough slack to allow the brush roll to come out.
    • While lifting the belt, pull/push upward away from the cleaner to pop it out.
    • It may seem like the brush rolls wont come out but just put more force into it.
  4. Hoover Power Path Deluxe FH50951 Nozzle Replacement, Belt: Schritt 4, Bild 1 von 2 Hoover Power Path Deluxe FH50951 Nozzle Replacement, Belt: Schritt 4, Bild 2 von 2
    • Gently slide the belt off of the motor shaft and lift it out of the vacuum.
    • Loop one end of the new belt around the motor shaft, making sure it sits securely in the groove.
    • Ensure the belt is securely placed in the correct slot on both the motor shaft and the brush roll. A loosely installed or improperly positioned belt can slip, break, or prevent the brush roll from spinning correctly, potentially damaging your vacuum. Double-check that the belt is aligned and tensioned properly before reassembling the vacuum.
  5. Hoover Power Path Deluxe FH50951 Nozzle Replacement, Water Dispenser: Schritt 5, Bild 1 von 2 Hoover Power Path Deluxe FH50951 Nozzle Replacement, Water Dispenser: Schritt 5, Bild 2 von 2
    • Remove the four 18.6 mm screws using a Phillips #1 screwdriver.
    • Remove the wheel assembly on the right side of the vacuum.
  6. Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 6, Bild 1 von 3 Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 6, Bild 2 von 3 Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 6, Bild 3 von 3
    • Remove the two 12.6 mm screws using a Phillips #1 screwdriver.
    • Remove the piece.
  7. Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 7, Bild 1 von 1
    • Hold the dispenser in one hand and the tube that is attached to the bottom in the other hand and pull.
    • It should just pull straight off, no twisting.
  8. Hoover Power Path Deluxe FH50951 Nozzle Replacement, Nozzle: Schritt 8, Bild 1 von 2 Hoover Power Path Deluxe FH50951 Nozzle Replacement, Nozzle: Schritt 8, Bild 2 von 2
    • Remove two 18.6 mm screws and one 12.6 mm screw from the right side of the vacuum.
    • Lift the right brush roll housing away from the device.
  9. Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 9, Bild 1 von 2 Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 9, Bild 2 von 2
    • Remove the two 12.6 mm screws from the left-side brush roll housing and belt guide using a Phillips #1 screwdriver.
    • Lift the left-side brush roll housing and belt guide away together from the device.
  10. Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 10, Bild 1 von 3 Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 10, Bild 2 von 3 Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 10, Bild 3 von 3
    • Remove the five 18.6 mm screws securing the nozzle to the vacuum using a Phillips #1 screwdriver.
    • By gripping the base of the device with your hands and pressing with your thumbs on the nozzle, press the nozzle away from the device.
    • Pull the nozzle away from the base to make removal easier.
  11. Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 11, Bild 1 von 2 Hoover Power Path Deluxe FH50951 Nozzle Replacement: Schritt 11, Bild 2 von 2
    • Carefully use the sharp end of a spudger to separate the hose gasket from a flange on the nozzle.
    • Use a circular motion around the edge of the flange to separate the gasket further.
    • With enough of the gasket lifted away from the flange, the nozzle can be pulled away from the hose.
Abschluss
Jon-Erik Hylle
259 Reputation
1 Anleitung geschrieben
Cuesta, Team 60-1, Krynen Fall 2024 Mitglied von Cuesta, Team 60-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 41
