Zum Hauptinhalt wechseln
IBM ThinkPad T43 CD Drive Replacement
aLiX pIeRRe
aLiX pIeRRe und 3 weitere Mitwirkende
Zuletzt aktualisiert am July 3, 2019
1 - 2 Minuten
Leicht
CD Drives can wear down and stop functioning correctly or stop entirely. This guide will show the user how to remove and replace the CD Drive
Was du brauchst
Werkzeuge
  1. IBM ThinkPad T43 CD Drive Replacement, CD Drive: Schritt 1, Bild 1 von 1
    • Start by having the right side of the laptop facing you.
    • The laptop can be open if you would like, but it can be done easier if it is closed.
  2. IBM ThinkPad T43 CD Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the screw to be able to use the CD drive unlock switch
  3. IBM ThinkPad T43 CD Drive Replacement: Schritt 3, Bild 1 von 1
    • Locate the switch on the right side of the CD Drive.
  4. IBM ThinkPad T43 CD Drive Replacement: Schritt 4, Bild 1 von 3 IBM ThinkPad T43 CD Drive Replacement: Schritt 4, Bild 2 von 3 IBM ThinkPad T43 CD Drive Replacement: Schritt 4, Bild 3 von 3
    • Place finger in between the switch and the bumper
    • Slide the switch to the right until the plastic tab ejects.
  5. IBM ThinkPad T43 CD Drive Replacement: Schritt 5, Bild 1 von 3 IBM ThinkPad T43 CD Drive Replacement: Schritt 5, Bild 2 von 3 IBM ThinkPad T43 CD Drive Replacement: Schritt 5, Bild 3 von 3
    • Place fingers on the plastic tab.
    • Pull on the tab until the CD Drive ejects.
    • The tab only comes out about an inch to inch and a half.
    • Do not try to pull the tab all the way out.
    • If after you have removed the CD Drive and the tab goes back in, it is alright. It does not affect the later process.
  6. IBM ThinkPad T43 CD Drive Replacement: Schritt 6, Bild 1 von 2 IBM ThinkPad T43 CD Drive Replacement: Schritt 6, Bild 2 von 2
    • Grab the end of the CD Drive and pulls straight out towards your body.
    • Be careful not to pull it out at an angle to not risk damage.
  7. IBM ThinkPad T43 CD Drive Replacement: Schritt 7, Bild 1 von 1
    • Now that you have successfully removed the CD Drive you can put in the new one.
    • Place the end of the new CD Drive in and slide in until it clicks.
    • If you are using slight force and it doesn't go in, it could be jammed. Just take it out and try again.
    • If you had not already, you can push back in the tab.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
aLiX pIeRRe
855 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S6-G4, Bernier Spring 2018
UMASSD-BERNIER-S18S6G4
4 Mitglieder
10 Anleitungen geschrieben
0Leitfaden Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 36
Insgesamt: 990
