Zum Hauptinhalt wechseln
India Mark III Head Replacement
Andrew Optimus Goldheart
Andrew Optimus Goldheart und 5 weitere Mitwirkende
Zuletzt aktualisiert am July 16, 2019
Keine Schätzung
Mittel
Follow this guide to remove the head of the India Mark III. You can then replace it or clean it, as necessary.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. India Mark III Head Replacement, Access Door: Schritt 1, Bild 1 von 2 India Mark III Head Replacement, Access Door: Schritt 1, Bild 2 von 2
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Remove the hex head bolt from the top of the access door on the pump head.
    • On reassembly, this bolt should be hand-tight.
  2. India Mark III Head Replacement: Schritt 2, Bild 1 von 3 India Mark III Head Replacement: Schritt 2, Bild 2 von 3 India Mark III Head Replacement: Schritt 2, Bild 3 von 3
    • Pull the access door straight up off the pump head.
    • Store the access door in a sanitary place to prevent contamination.
  3. India Mark III Head Replacement: Schritt 3, Bild 1 von 2 India Mark III Head Replacement: Schritt 3, Bild 2 von 2
    • The access door has a tongue that fits into the base of the pump head.
    • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
  4. India Mark III Head Replacement, Chain: Schritt 4, Bild 1 von 3 India Mark III Head Replacement, Chain: Schritt 4, Bild 2 von 3 India Mark III Head Replacement, Chain: Schritt 4, Bild 3 von 3
    • Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
  5. India Mark III Head Replacement: Schritt 5, Bild 1 von 3 India Mark III Head Replacement: Schritt 5, Bild 2 von 3 India Mark III Head Replacement: Schritt 5, Bild 3 von 3
    • The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
    • Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
  6. India Mark III Head Replacement: Schritt 6, Bild 1 von 3 India Mark III Head Replacement: Schritt 6, Bild 2 von 3 India Mark III Head Replacement: Schritt 6, Bild 3 von 3
    • Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
  7. India Mark III Head Replacement: Schritt 7, Bild 1 von 3 India Mark III Head Replacement: Schritt 7, Bild 2 von 3 India Mark III Head Replacement: Schritt 7, Bild 3 von 3
    • Hold the wrench on the bolt stationary.
    • Loosen the nut.
  8. India Mark III Head Replacement: Schritt 8, Bild 1 von 3 India Mark III Head Replacement: Schritt 8, Bild 2 von 3 India Mark III Head Replacement: Schritt 8, Bild 3 von 3
    • Remove the nut from the chain bolt.
  9. India Mark III Head Replacement: Schritt 9, Bild 1 von 2 India Mark III Head Replacement: Schritt 9, Bild 2 von 2
    • Remove the washer from the chain bolt.
  10. India Mark III Head Replacement: Schritt 10, Bild 1 von 2 India Mark III Head Replacement: Schritt 10, Bild 2 von 2
    • Remove the chain bolt.
  11. India Mark III Head Replacement: Schritt 11, Bild 1 von 3 India Mark III Head Replacement: Schritt 11, Bild 2 von 3 India Mark III Head Replacement: Schritt 11, Bild 3 von 3
    • Pull the top of the chain straight off of the pump handle.
  12. India Mark III Head Replacement, Head: Schritt 12, Bild 1 von 3 India Mark III Head Replacement, Head: Schritt 12, Bild 2 von 3 India Mark III Head Replacement, Head: Schritt 12, Bild 3 von 3
    • Remove the two bolts from the handle side of the pump head.
    • Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
  13. India Mark III Head Replacement: Schritt 13, Bild 1 von 3 India Mark III Head Replacement: Schritt 13, Bild 2 von 3 India Mark III Head Replacement: Schritt 13, Bild 3 von 3
    • Remove the two bolts and nuts from the handle side.
  14. India Mark III Head Replacement: Schritt 14, Bild 1 von 2 India Mark III Head Replacement: Schritt 14, Bild 2 von 2
    • After removing the two handle side bolts, have your partner support the weight of the handle.
    • Remove the two remaining bolts in the same fashion.
  15. India Mark III Head Replacement: Schritt 15, Bild 1 von 3 India Mark III Head Replacement: Schritt 15, Bild 2 von 3 India Mark III Head Replacement: Schritt 15, Bild 3 von 3
    • Lift and remove the pump head from the pump.
    • Store the pump head in a sanitary place, preferably above ground, to prevent contamination.
Abschluss
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.600 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 211
