Zum Hauptinhalt wechseln
Keurig K-Duo Water Pump Replacement
Jacob Archer
Jacob Archer und 2 weitere Mitwirkende
Zuletzt aktualisiert am December 30, 2024
10 - 20 Minuten
Mittel
This guide will show you how to replace the water pump in a Keurig K-Duo. Replacing the water pump may be necessary in the event that there is no water coming out.
The water pump is a crucial component that moves water through the system for brewing coffee. Over time, these pumps can fail for several reasons, ranging from wear and tear to improper maintenance or environmental factors.
Was du brauchst
Werkzeuge
  1. Keurig K-Duo Water Pump Replacement, Rear Plastic Panels: Schritt 1, Bild 1 von 1
    • Turn the Keurig K-Duo upside down so the power cord is visible and facing you.
  2. Keurig K-Duo Water Pump Replacement: Schritt 2, Bild 1 von 3 Keurig K-Duo Water Pump Replacement: Schritt 2, Bild 2 von 3 Keurig K-Duo Water Pump Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips screwdriver to remove all four screws that secure the plastic panel.
  3. Keurig K-Duo Water Pump Replacement: Schritt 3, Bild 1 von 3 Keurig K-Duo Water Pump Replacement: Schritt 3, Bild 2 von 3 Keurig K-Duo Water Pump Replacement: Schritt 3, Bild 3 von 3
    • To remove the back panels, grip each side firmly.
    • Gently pull the panel outward toward yourself to release and fully detach the plastic hooks.
  4. Keurig K-Duo Water Pump Replacement, Water Pump: Schritt 4, Bild 1 von 2 Keurig K-Duo Water Pump Replacement, Water Pump: Schritt 4, Bild 2 von 2
    • There are two terminal blocks to remove from the motherboard.
    • Gently disconnect the 2-pin terminal block that has the label "Water Pump" on the motherboard.
    • Gently disconnect the 4-pin terminal block that has the label "IR Sensor."
  5. Keurig K-Duo Water Pump Replacement: Schritt 5, Bild 1 von 3 Keurig K-Duo Water Pump Replacement: Schritt 5, Bild 2 von 3 Keurig K-Duo Water Pump Replacement: Schritt 5, Bild 3 von 3
    • Pull out the water pump from its socket by twisting it so that the bottom is facing you.
    • Remove the plastic tubes from water pump.
  6. Keurig K-Duo Water Pump Replacement: Schritt 6, Bild 1 von 2 Keurig K-Duo Water Pump Replacement: Schritt 6, Bild 2 von 2
    • Fully access the water pump by pulling it straight out.
    • Make sure none of the disconnected wires are caught on any of the motherboard components to avoid damage.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Jacob Archer
197 Reputation
1 Anleitung geschrieben
Cuesta, Team 10-3, Krynen Fall 2024 Mitglied von Cuesta, Team 10-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 25
Letzte 30 Tage: 94
Insgesamt: 231
