Zum Hauptinhalt wechseln
LG G3 Vigor Earpiece Speaker Replacement
Geoff Wacker
Geoff Wacker
Zuletzt aktualisiert am May 25, 2016
Keine Schätzung
Mittel
Benötigt Mehr Bilder
Use this guide to replace the earpiece speaker in your LG G3 Vigor.
Was du brauchst
Werkzeuge
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Mehr anzeigen …
  1. LG G3 Vigor Earpiece Speaker Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Earpiece Speaker Replacement: Schritt 2, Bild 1 von 1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Earpiece Speaker Replacement, Battery: Schritt 3, Bild 1 von 1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Earpiece Speaker Replacement, Midframe: Schritt 4, Bild 1 von 1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Earpiece Speaker Replacement: Schritt 5, Bild 1 von 3 LG G3 Vigor Earpiece Speaker Replacement: Schritt 5, Bild 2 von 3 LG G3 Vigor Earpiece Speaker Replacement: Schritt 5, Bild 3 von 3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Earpiece Speaker Replacement, Rear Facing Camera: Schritt 6, Bild 1 von 1
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Earpiece Speaker Replacement, Front Facing Camera: Schritt 7, Bild 1 von 2 LG G3 Vigor Earpiece Speaker Replacement, Front Facing Camera: Schritt 7, Bild 2 von 2
    • Remove the front camera.
  8. LG G3 Vigor Earpiece Speaker Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Earpiece Speaker Replacement: Schritt 9, Bild 1 von 2 LG G3 Vigor Earpiece Speaker Replacement: Schritt 9, Bild 2 von 2
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Earpiece Speaker Replacement, Earpiece Speaker: Schritt 10, Bild 1 von 1
    • Remove the earpiece speaker with the metal spudger by prying it out.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Geoff Wacker
91.128 Reputation
89 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 288
