Lenovo IdeaPad 3-15IML05 Fan Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide will walk you through the process of replacing the fan in your Lenovo IdeaPad 3-15IML05. Over time, dust or a faulty fan can lead to overheating and system issues. By following these steps, you'll be able to replace the fan y and restore optimal cooling performance to your laptop.
Before you begin this repair, make sure that your laptop is off and disconnected from the power adapter.
Use a Phillips #1 screw driver to remove:
Six 5.0 mm screws
Four 3.0 mm screws
Use an opening tool to pry the bottom cover from the device.
Use the opening tool to go around the entire perimeter, releasing the tabs that secure the cover to the frame.
Carefully remove the cover.
Use a Phillips screwdriver to remove the three screws securing the battery to the frame.
Use the point of a spudger to push on alternating sides of the sliding connector to "walk" it out of its socket on the motherboard.
Use a Phillips screwdriver to remove the three screws securing the fan to the chassis.
Grip the tab at the end of the bundle cable and pull the connector slowly and steadily out of its socket to disconnect the fan cable.
Disconnect the fan from the heat sink.
Gently unhook the black wire from the tabs around the edge of the fan.
Lift the fan from the laptop to remove it.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
