Zum Hauptinhalt wechseln
Lenovo Thinkpad X220 Keyboard Replacement
alphaLONE
alphaLONE und 4 weitere Mitwirkende
Zuletzt aktualisiert am February 7, 2023
5 Minuten
Leicht
Anleitung eines Community-Mitglieds
I will replace the keyboard on this Thinkpad X220 in a few steps.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Lenovo Thinkpad X220 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Lenovo Thinkpad X220 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Lenovo Thinkpad X220 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the two switches that lock the battery.
    • Then push the left switch outward into the "unlocked" position.
    • This switch will remain in the unlocked position.
  2. Lenovo Thinkpad X220 Keyboard Replacement: Schritt 2, Bild 1 von 2 Lenovo Thinkpad X220 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Now push and hold the right switch to the right while using the other hand to gently slide the battery upwards out of the laptop.
  3. Lenovo Thinkpad X220 Keyboard Replacement: Schritt 3, Bild 1 von 2 Lenovo Thinkpad X220 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • This is a rechargeable Li-Ion battery that has a capacity of 4400 mAh, if you have the 6 cell model.
    • The 4 or 9 cell model has different ratings.
  4. Lenovo Thinkpad X220 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 1
    • Put the laptop upside down.
    • Unscrew the two keyboard retention screws.
  5. Lenovo Thinkpad X220 Keyboard Replacement: Schritt 5, Bild 1 von 2 Lenovo Thinkpad X220 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Put the laptop back on its feet, open the lid and push the keyboard from the TrackPoint click buttons.
    • After that, pull it from the laptop assembly.
  6. Lenovo Thinkpad X220 Keyboard Replacement: Schritt 6, Bild 1 von 2 Lenovo Thinkpad X220 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • You should now have access to the keyboard's connector.
    • Pull it gently from the grabbing tip.
  7. Lenovo Thinkpad X220 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • The keyboard is now totally unplugged from the laptop.
    • Here you go! Plug a new keyboard on the connector and follow the steps in the reverse order to finish your repair.
Ziellinie
10 weitere Personen haben diese Anleitung absolviert.
alphaLONE
975 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 15
Letzte 30 Tage: 59
Insgesamt: 6,537
