Lenovo Yoga 3 11 Battery Replacement
Einleitung
Zu Schritt 1 der AnleitungIf your battery does not hold as much charge as it used to and you need to replace it, then you have come to the right place! This guide will show you how to successfully remove and replace the battery.
Was du brauchst
Remove the eleven 6 mm T5 Torx screws securing the lower case.
Gently lift the lower case up and away from the device.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a pair of tweezers to gently disconnect the battery connector.
Use a pair of tweezers to gently disconnect the speaker cable.
Remove the wires from underneath the battery tabs using the tweezers.
Eine weitere Person hat diese Anleitung absolviert.
