Zum Hauptinhalt wechseln
Motorola Moto Z3 Play Battery Replacement
Was du brauchst
    1. Motorola Moto Z3 Play Battery Replacement, Heat the Display: Schritt 1, Bild 1 von 1
      • Power your phone off before you begin.
      • If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
      • If your display is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
      • Prepare an iOpener and heat the front of the phone along its right edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the display.
      • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Frag FixBot
      Kommentar hinzufügen
    2. Motorola Moto Z3 Play Battery Replacement, Display Adhesive Cutting Reference: Schritt 2, Bild 1 von 2 Motorola Moto Z3 Play Battery Replacement, Display Adhesive Cutting Reference: Schritt 2, Bild 2 von 2
      • In the following steps, you will separate the display assembly from the Moto Z3 Play's chassis.
      • The first image shows the back of the display assembly after it has been removed from the phone. The second image shows the front of the phone to reference where the display cable lies.
      • If you plan to re-use the display assembly, pay particular attention to the side edges. When slicing through the glue in this area, you must be careful to insert your tool less than ~1.5 mm, or your tool will come in contact with the LCD and damage it.
      • Take special care when cutting near the display cable. If you pry too deep or too forcefully, it is very easy to damage the cable. If you encounter extra resistance around this area, do not try to force the pick forward. Pull it out and reinsert it on the other side of the display cable before you continue cutting.
      • Playing cards are a safer, but much slower, prying tool. The soft paper cards are less likely to damage the LCD, which is good news if you plan to reuse it.
      Frag FixBot
    3. Motorola Moto Z3 Play Battery Replacement, Cut the Display Adhesive: Schritt 3, Bild 1 von 3 Motorola Moto Z3 Play Battery Replacement, Cut the Display Adhesive: Schritt 3, Bild 2 von 3 Motorola Moto Z3 Play Battery Replacement, Cut the Display Adhesive: Schritt 3, Bild 3 von 3
      • Apply a suction cup to the display, near the middle of the right edge.
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the display and rear case.
      • If the screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
      • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
      • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
      • Insert an opening pick (or playing card) into the gap you opened behind the display.
      • Do not insert the tool more than ~1.5 mm past the edge of the display.
      Frag FixBot
    4. Motorola Moto Z3 Play Battery Replacement: Schritt 4, Bild 1 von 3 Motorola Moto Z3 Play Battery Replacement: Schritt 4, Bild 2 von 3 Motorola Moto Z3 Play Battery Replacement: Schritt 4, Bild 3 von 3
      • Slide the tool all along the right edge of the phone to slice through the adhesive securing the display.
      • If you plan to reuse the display, continue moving the tool in a straight line as you approach the corners of the phone—do not round the corners with the tool. The corners of the LCD come very close to the edge of the digitizer and are easy to damage.
      Frag FixBot
    5. Motorola Moto Z3 Play Battery Replacement: Schritt 5, Bild 1 von 1
      • Heat the upper edge of the display to soften the adhesive underneath.
      Frag FixBot
    6. Motorola Moto Z3 Play Battery Replacement: Schritt 6, Bild 1 von 3 Motorola Moto Z3 Play Battery Replacement: Schritt 6, Bild 2 von 3 Motorola Moto Z3 Play Battery Replacement: Schritt 6, Bild 3 von 3
      • Slide your tool underneath the top bezel to separate the glue.
      • You can insert the pick slightly deeper here, but if you want to re-use the display, don't insert the tool more than ~5.5 mm past the edge of the display.
      Frag FixBot
    7. Motorola Moto Z3 Play Battery Replacement: Schritt 7, Bild 1 von 1
      • Heat the left edge of the phone to soften the adhesive securing the left edge of the display.
      Frag FixBot
    8. Motorola Moto Z3 Play Battery Replacement: Schritt 8, Bild 1 von 3 Motorola Moto Z3 Play Battery Replacement: Schritt 8, Bild 2 von 3 Motorola Moto Z3 Play Battery Replacement: Schritt 8, Bild 3 von 3
      • Slide your tool along the left edge of the phone to separate the glue securing the display.
      • Be very careful when slicing near the bottom of the phone to avoid damaging the display cable. Refer to step two for help identifying and avoiding the display cable.
      Frag FixBot
    9. Motorola Moto Z3 Play Battery Replacement: Schritt 9, Bild 1 von 1
      • Heat the bottom edge of the phone to soften the adhesive securing the bottom of the display.
      Frag FixBot
    10. Motorola Moto Z3 Play Battery Replacement: Schritt 10, Bild 1 von 3 Motorola Moto Z3 Play Battery Replacement: Schritt 10, Bild 2 von 3 Motorola Moto Z3 Play Battery Replacement: Schritt 10, Bild 3 von 3
      • Slice through the glue under the lower bezel.
      • You can insert the pick slightly deeper here, but if you want to re-use the display, don't insert the tool more than ~4 mm past the edge of the display.
      Frag FixBot
    11. Motorola Moto Z3 Play Battery Replacement, Remove the Display: Schritt 11, Bild 1 von 1
      • If the display remains stuck, re-heat and slice the adhesive repeatedly as needed.
      • Lift the display from the right edge and swing it open, away from the phone. The display is still attached to the phone chassis at the lower left edge, so do not fully remove it yet.
      • When you lift the display, a small plastic gasket— for the front-facing sensors—may fall out of the phone. Keep track of this gasket and make sure to reinstall it before sealing the phone.
      Frag FixBot
    12. Motorola Moto Z3 Play Battery Replacement: Schritt 12, Bild 1 von 2 Motorola Moto Z3 Play Battery Replacement: Schritt 12, Bild 2 von 2
      • Use the point of a spudger to pry up the locking tab on the display cable's ZIF connector.
      Frag FixBot
    13. Motorola Moto Z3 Play Battery Replacement: Schritt 13, Bild 1 von 1
      Frag FixBot
    1. Motorola Moto Z3 Play Battery Replacement, Remove Tape: Schritt 14, Bild 1 von 1
      In diesem Schritt verwendetes Werkzeug:
      • Use tweezers to peel up the black tape covering the battery connector and battery.
      • If possible, avoid damaging the tape so that it can be reused.
      Frag FixBot
    2. Motorola Moto Z3 Play Battery Replacement: Schritt 15, Bild 1 von 1
      • Use tweezers to peel off and remove the red tape covering the battery connector.
      Frag FixBot
    3. Motorola Moto Z3 Play Battery Replacement, Disconnect the Battery: Schritt 16, Bild 1 von 2 Motorola Moto Z3 Play Battery Replacement, Disconnect the Battery: Schritt 16, Bild 2 von 2
      • Use the point of a spudger to pry the battery connector straight up and disconnect it.
      Frag FixBot
    4. Motorola Moto Z3 Play Battery Replacement, Remove Tape: Schritt 17, Bild 1 von 1
      • Use tweezers to peel up and remove the black tape at the bottom of the battery.
      Frag FixBot
    5. Motorola Moto Z3 Play Battery Replacement, Remove Earpiece and Sensor Assembly: Schritt 18, Bild 1 von 2 Motorola Moto Z3 Play Battery Replacement, Remove Earpiece and Sensor Assembly: Schritt 18, Bild 2 von 2
      • There may two pieces of silver tape covering screws in the top corners of the device. If this is the case, carefully peel the tape back to access the screws, and replace it during reassembly.
      Frag FixBot
    6. Motorola Moto Z3 Play Battery Replacement: Schritt 19, Bild 1 von 1
      • Remove six 3 mm-long T3 Torx screws securing the earpiece assembly.
      Frag FixBot
    7. Motorola Moto Z3 Play Battery Replacement: Schritt 20, Bild 1 von 2 Motorola Moto Z3 Play Battery Replacement: Schritt 20, Bild 2 von 2
      • Insert the point of a spudger into the small rectangular opening on the right edge of the earpiece speaker and sensor assembly.
      • Use the spudger to pry the assembly up and release the clips securing it to the phone chassis.
      Frag FixBot
    8. Motorola Moto Z3 Play Battery Replacement: Schritt 21, Bild 1 von 1
      • Remove the earpiece speaker and sensor assembly.
      • The earpiece speaker connector sits under the assembly and will disconnect as you lift the assembly. During reassembly, make sure to reconnect this connector.
      Frag FixBot
    9. Motorola Moto Z3 Play Battery Replacement, Disconnect the Fingerprint Sensor: Schritt 22, Bild 1 von 2 Motorola Moto Z3 Play Battery Replacement, Disconnect the Fingerprint Sensor: Schritt 22, Bild 2 von 2
      • Use the flat end of a spudger to lift the fingerprint sensor connector straight up and out of its socket.
      Frag FixBot
    10. Motorola Moto Z3 Play Battery Replacement: Schritt 23, Bild 1 von 1
      • Use tweezers to gently bend the cable toward the edge of the phone so it is out of the way of the battery.
      Frag FixBot
    11. Motorola Moto Z3 Play Battery Replacement, Remove the Battery: Schritt 24, Bild 1 von 1
      • Apply a freshly heated iOpener to the back of the phone directly behind the battery for two minutes to help soften the adhesive. Re-heat and reapply the iOpener as necessary.
      • Alternatively, apply high-concentration (>90%) isopropyl alcohol under the edge of the battery to weaken the adhesive underneath.
      • Let the phone sit for several minutes to allow the alcohol to penetrate and weaken the adhesive.
      Frag FixBot
    12. Motorola Moto Z3 Play Battery Replacement: Schritt 25, Bild 1 von 2 Motorola Moto Z3 Play Battery Replacement: Schritt 25, Bild 2 von 2
      Plastic Cards
      $2.99
      • Insert an opening pick or a plastic card along the edge of the battery.
      • Apply steady, even pressure to slowly lever the battery up and out of the phone.
      • If necessary, use several rounds of heating or alcohol, and pressure to slowly weaken the adhesive, and the battery will begin to separate.
      • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
      Frag FixBot
    13. Motorola Moto Z3 Play Battery Replacement: Schritt 26, Bild 1 von 2 Motorola Moto Z3 Play Battery Replacement: Schritt 26, Bild 2 von 2
      Tesa 61395 Tape
      $8.95
      • Continue pulling up the battery until all the adhesive releases from the rear case.
      • Remove the battery.
      • Reusing a deformed or bent battery after it has forcefully been removed is a safety hazard. Replace it with a new battery.
      • Before installing your new battery, peel up all the old adhesive and remove it from the phone.
      • For best results, clean the area underneath the battery with isopropyl alcohol and a lint-free cloth or coffee filter. This helps prep the surface so the new battery can adhere more strongly. Apply stretch release adhesive strips, double-sided tape, or pre-cut adhesive strips to install the new battery.
      Frag FixBot
Abschluss
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Check out our Answers community for troubleshooting help.
7 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Thank you for the tutorial. I was able to successfully replace the original swollen battery and everything is working great. HOWEVER… in step 20 I was unable to pry up the sensor assembly, as it was requiring more force than I was comfortable applying. So I couldn’t disconnect the fingerprint sensor ribbon cable, and had to VERY CAREFULLY loosen the battery using heat and alcohol without breaking the ribbon.
All’s well that ends well, but is there a trick to to getting that sensor assembly out? Is there maybe some glue under it? I got all six screws out but it was flexing way too much when I tried to pry it out.
fb100 - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 52
Insgesamt: 8,639
