Shark Clean Sense HP102PET Sensor Replacement
Einleitung
Zu Schritt 1 der AnleitungUse this guide to replace the sensor in your Shark Clean Sense HP102PET. The sensor allows the device to register whenever you use the LED touch screen feature.
Was du brauchst
Unscrew the one 1.2 cm screw holding the grate at the top with a TR10 Torx screwdriver.
Use a prying tool to carefully pry along the outer edges to disengage the inner retaining clips.
Remove the grate.
Flip the device over and unscrew the bottom by turning it clockwise.
Remove the filter.
Remove the five 1 cm a Phillips screwdriver.
Unscrew the four 1.2 cm screws with a TR10 Torx screwdriver.
Make sure that you are pulling up on the side that allows, as pictured in the red box.
Gently slide the cases up and down, or hold one and gently pull up on the opposite side (Down on the left, up on the right for this picture).
Gently open the case outwards as there are fragile electronics inside.
Remove the fan housing.
Gently pull housing outwards, to where you can easily access the portion circled in the third picture.
Gently close the shell and progressively tilt it to where it is laying on its side.
With the casing loose, return the shell to the upright position, as this will help with maneuvering the case to access the inside.
The sensor should rotate counter-clockwise, allowing the red and white wire to rotate with it so that it doesn't disconnect.
Rotate the sensor and make sure that the sensors are free from any blockages or gunk that could be interfering with the sensor or replace the sensor as needed.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
