Zum Hauptinhalt wechseln
Toro Cement Mixer 68009HD 2018 Spindle Replacement
Arthur Shi
Arthur Shi
Zuletzt aktualisiert am December 9, 2020
30 Minuten - 1 Stunde
Mittel
This guide shows how to remove and replace the spindle for the Toro Cement Mixer 68009HD.
The spindle attaches the tub to the yoke and allows the tub to spin freely.
Warning: The tub and dish are both extremely heavy and require at least two people to lift them. Be sure to practice safe lifting techniques.
  1. Toro Cement Mixer 68009HD 2018 Spindle Replacement, Safety precautions: Schritt 1, Bild 1 von 2 Toro Cement Mixer 68009HD 2018 Spindle Replacement, Safety precautions: Schritt 1, Bild 2 von 2
    • Before you begin, press the engine-stop switch to turn off the engine.
  2. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 2, Bild 1 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 2, Bild 2 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 2, Bild 3 von 3
    • Unlatch the three rubber straps securing the cowl.
  3. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 3, Bild 1 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 3, Bild 2 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 3, Bild 3 von 3
    • Swing the cowl up until it rests securely on the frame.
  4. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 4, Bild 1 von 2 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 4, Bild 2 von 2
    • Slide the fuel cutoff lever to the left to cut the fuel supply to the engine.
  5. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 5, Bild 1 von 2 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 5, Bild 2 von 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  6. Toro Cement Mixer 68009HD 2018 Spindle Replacement, Remove the tub: Schritt 6, Bild 1 von 2 Toro Cement Mixer 68009HD 2018 Spindle Replacement, Remove the tub: Schritt 6, Bild 2 von 2
    • Pull up on the brake lever to disengage the brake.
  7. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 7, Bild 1 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 7, Bild 2 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 7, Bild 3 von 3
    • Rotate the tub until the yoke and dish assembly sit directly below the tub.
  8. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 8, Bild 1 von 2 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 8, Bild 2 von 2
    • Push down on the brake lever to re-engage the brake.
    • Make sure that the brake is fully engaged.
  9. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 9, Bild 1 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 9, Bild 2 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 9, Bild 3 von 3
    • Use a 3/4 inch socket to remove the six nuts securing the tub to the dish.
  10. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 10, Bild 1 von 1
    • Remove the six drum clamp plates from the tub mounting points.
  11. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 11, Bild 1 von 1
    • Lift the tub up slightly by the gear ring to loosen the tub from the dish.
  12. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 12, Bild 1 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 12, Bild 2 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 12, Bild 3 von 3
    • The tub is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
    • Lift the tub straight up from the dish and remove it from the device.
  13. Toro Cement Mixer 68009HD 2018 Spindle Replacement, Remove the dish: Schritt 13, Bild 1 von 2 Toro Cement Mixer 68009HD 2018 Spindle Replacement, Remove the dish: Schritt 13, Bild 2 von 2
    • Use a large crescent wrench to remove the bolt securing the dish to the bottom of the yoke.
  14. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 14, Bild 1 von 1
    • Use a 3/4 inch socket to remove the lock bolt from the yoke.
  15. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 15, Bild 1 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 15, Bild 2 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 15, Bild 3 von 3
    • The dish is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
    • Lift the dish straight up and remove it from the yoke.
    • A convenient place to set the dish is on top of the removed tub.
  16. Toro Cement Mixer 68009HD 2018 Spindle Replacement, Reassembly tip: Schritt 16, Bild 1 von 2 Toro Cement Mixer 68009HD 2018 Spindle Replacement, Reassembly tip: Schritt 16, Bild 2 von 2
    • During reassembly, be sure to align the shaft indent with the lock bolt hole as you set the dish in place. Otherwise, you will not be able to properly lock the shaft and tighten the dish bolt.
  17. Toro Cement Mixer 68009HD 2018 Spindle Replacement, Remove the spindle: Schritt 17, Bild 1 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement, Remove the spindle: Schritt 17, Bild 2 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement, Remove the spindle: Schritt 17, Bild 3 von 3
    • Use a pipe wrench or an extra-large crescent wrench to loosen the dish plug.
    • Remove the dish plug.
  18. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 18, Bild 1 von 2 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 18, Bild 2 von 2
    • The spindle and bearings are very greasy. Handle these components carefully to avoid getting grease everywhere.
    • Push the spindle from the bottom of the dish.
  19. Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 19, Bild 1 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 19, Bild 2 von 3 Toro Cement Mixer 68009HD 2018 Spindle Replacement: Schritt 19, Bild 3 von 3
    • Pull the spindle from the top of the dish and remove it.
    • After you reassemble the device, make sure to follow manufacturer instructions on how to properly lubricate the device with a grease gun.
Abschluss
Arthur Shi
282.883 Reputation
587 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
119 Mitglieder
19.481 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 191
