Toshiba Satellite C655D-S5084 Hard Drive Replacement
Einleitung
Zu Schritt 1 der AnleitungIf your computer is running slow and needs a little pick me up, one option is to replace or upgrade your hard drive. This guide will show you how to remove your hard drive and install a replacement in your Toshiba Satellite C655D-S5084.
Was du brauchst
Werkzeuge
Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
Remove the plastic cover.
Remove the 2.5 mm screw (F3) inside the hard drive casing using the Phillips #1 screwdriver.
4 weitere Personen haben diese Anleitung absolviert.
