Einleitung
If your computer is running slow and needs a little pick me up, one option is to replace or upgrade your hard drive. This guide will show you how to remove your hard drive and install a replacement in your Toshiba Satellite C655D-S5084.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Unscrew the 5.5 mm "F5" screw using the Phillips #0 screwdriver, and carefully remove the plastic cover.
Remove the 2.5 mm screw labeled "F3" inside the hard drive casing (on the small metal tab of the hard drive) using the Phillips #1 screwdriver.
Place your thumb on the large metal tab on the hard drive and slide toward yourself, away from its base attachment.
Use your finger to lift the large metal tab on the hard drive to remove completely.
3 weitere Nutzer haben diese Anleitung absolviert.
