Zum Hauptinhalt wechseln
Xiaomi Redmi Note 8 Battery Replacement
Was du brauchst
  1. Xiaomi Redmi Note 8 Battery Replacement, Heat the rear glass: Schritt 1, Bild 1 von 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Xiaomi Redmi Note 8 Battery Replacement, Insert an opening pick: Schritt 2, Bild 1 von 3 Xiaomi Redmi Note 8 Battery Replacement, Insert an opening pick: Schritt 2, Bild 2 von 3 Xiaomi Redmi Note 8 Battery Replacement, Insert an opening pick: Schritt 2, Bild 3 von 3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Xiaomi Redmi Note 8 Battery Replacement, Slice the adhesive: Schritt 3, Bild 1 von 2 Xiaomi Redmi Note 8 Battery Replacement, Slice the adhesive: Schritt 3, Bild 2 von 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Redmi Note 8 Battery Replacement, Slice the adhesive: Schritt 4, Bild 1 von 3 Xiaomi Redmi Note 8 Battery Replacement, Slice the adhesive: Schritt 4, Bild 2 von 3 Xiaomi Redmi Note 8 Battery Replacement, Slice the adhesive: Schritt 4, Bild 3 von 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Redmi Note 8 Battery Replacement: Schritt 5, Bild 1 von 2 Xiaomi Redmi Note 8 Battery Replacement: Schritt 5, Bild 2 von 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 8 Battery Replacement: Schritt 6, Bild 1 von 2 Xiaomi Redmi Note 8 Battery Replacement: Schritt 6, Bild 2 von 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    • Don't try to remove the rear glass all the way yet. The camera cover and fingerprint assembly is still adhered to its back.
  7. Xiaomi Redmi Note 8 Battery Replacement, Open your phone: Schritt 7, Bild 1 von 3 Xiaomi Redmi Note 8 Battery Replacement, Open your phone: Schritt 7, Bild 2 von 3 Xiaomi Redmi Note 8 Battery Replacement, Open your phone: Schritt 7, Bild 3 von 3
    • Carefully fold the rear glass to the right side of the phone assembly like you'd open the back cover of a book.
    • Avoid straining the finger print cable during this procedure.
  8. Xiaomi Redmi Note 8 Battery Replacement, Disconnect the fingerprint reader: Schritt 8, Bild 1 von 3 Xiaomi Redmi Note 8 Battery Replacement, Disconnect the fingerprint reader: Schritt 8, Bild 2 von 3 Xiaomi Redmi Note 8 Battery Replacement, Disconnect the fingerprint reader: Schritt 8, Bild 3 von 3
    • Use a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
    • Remove the rear glass assembly.
  9. Xiaomi Redmi Note 8 Battery Replacement, Unfasten the motherboard cover screws: Schritt 9, Bild 1 von 1
    • Use screwdriver to remove the eleven screws securing the motherboard cover:
    • Ten 3.9 mm-long Phillips screws
    • One 3.4 mm-long Phillips screw
  10. Xiaomi Redmi Note 8 Battery Replacement, Pry up the motherboard cover: Schritt 10, Bild 1 von 3 Xiaomi Redmi Note 8 Battery Replacement, Pry up the motherboard cover: Schritt 10, Bild 2 von 3 Xiaomi Redmi Note 8 Battery Replacement, Pry up the motherboard cover: Schritt 10, Bild 3 von 3
    • Insert the tip of an opening pick underneath the bottom left edge of the motherboard cover.
    • Do not insert the opening pick deeper than 3-4 mm to prevent damaging the motherboard.
    • Slide the opening pick along the left edge of the motherboard cover to unhinge the plastic clips and pry it up.
  11. Xiaomi Redmi Note 8 Battery Replacement: Schritt 11, Bild 1 von 2 Xiaomi Redmi Note 8 Battery Replacement: Schritt 11, Bild 2 von 2
    • Insert the tip of an opening pick underneath the bottom right edge of the motherboard cover.
    • Slide the opening pick along the right edge of the motherboard cover to unhinge the plastic clips and pry it up.
  12. Xiaomi Redmi Note 8 Battery Replacement, Remove the motherboard cover: Schritt 12, Bild 1 von 2 Xiaomi Redmi Note 8 Battery Replacement, Remove the motherboard cover: Schritt 12, Bild 2 von 2
    • Remove the motherboard cover.
  13. Xiaomi Redmi Note 8 Battery Replacement, Disconnect the battery: Schritt 13, Bild 1 von 2 Xiaomi Redmi Note 8 Battery Replacement, Disconnect the battery: Schritt 13, Bild 2 von 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  14. Xiaomi Redmi Note 8 Battery Replacement, Disconnect the interconnect flex cable: Schritt 14, Bild 1 von 2 Xiaomi Redmi Note 8 Battery Replacement, Disconnect the interconnect flex cable: Schritt 14, Bild 2 von 2
    • Use a spudger to disconnect the interconnect flex cable by prying the connector straight up from its socket.
  15. Xiaomi Redmi Note 8 Battery Replacement, Disconnect the display flex cable: Schritt 15, Bild 1 von 2 Xiaomi Redmi Note 8 Battery Replacement, Disconnect the display flex cable: Schritt 15, Bild 2 von 2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  16. Xiaomi Redmi Note 8 Battery Replacement, Free the battery: Schritt 16, Bild 1 von 3 Xiaomi Redmi Note 8 Battery Replacement, Free the battery: Schritt 16, Bild 2 von 3 Xiaomi Redmi Note 8 Battery Replacement, Free the battery: Schritt 16, Bild 3 von 3
    • During the following steps, do not fold the cable sharply and only bend it to avoid cable damage.
    • Fold the display flex cable towards the charging port in order to get free access to the battery.
    • You might want to use a small piece of tape to temporarily stick the cable onto your working surface to avoid accidentally damaging it during the battery removal.
    • Repeat the previous step and fold the interconnect flex cable in direction of the charging port.
  17. Xiaomi Redmi Note 8 Battery Replacement, Remove the stretch-release adhesive: Schritt 17, Bild 1 von 3 Xiaomi Redmi Note 8 Battery Replacement, Remove the stretch-release adhesive: Schritt 17, Bild 2 von 3 Xiaomi Redmi Note 8 Battery Replacement, Remove the stretch-release adhesive: Schritt 17, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • The battery is secured to the rear case with two pieces of stretch-release adhesive.
    • Use a pair of tweezers or a clean fingernail to peel down both battery adhesive pull-tabs to un-stick them from the bottom edge of the battery.
    • Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  18. Xiaomi Redmi Note 8 Battery Replacement, Remove the pull-tabs: Schritt 18, Bild 1 von 2 Xiaomi Redmi Note 8 Battery Replacement, Remove the pull-tabs: Schritt 18, Bild 2 von 2
    • Grab the right pull-tab with a pair of tweezers or your fingers and slowly pull it away from the battery and towards the bottom edge of your phone.
    • Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
    • Don't press down on the battery. Hold the Redmi firmly by its sides.
    • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
    • Pull at a low angle so the strip doesn't snag on the edge of the battery.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
    • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
  19. Xiaomi Redmi Note 8 Battery Replacement: Schritt 19, Bild 1 von 2 Xiaomi Redmi Note 8 Battery Replacement: Schritt 19, Bild 2 von 2
    Plastic Cards
    $2.99
    Kaufen
    • Repeat the previous pull-tab removal procedure on the second pull-tab.
    • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
    • If the adhesive breaks off underneath the battery and can't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use the flat end of an opening pick or a plastic card to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  20. Xiaomi Redmi Note 8 Battery Replacement, Remove the battery: Schritt 20, Bild 1 von 2 Xiaomi Redmi Note 8 Battery Replacement, Remove the battery: Schritt 20, Bild 2 von 2
    • Remove the battery.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
Abschluss
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
13 weitere Nutzer:innen haben diese Anleitung absolviert.
Dominik Schnabelrauch
205.055 Reputation
682 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
2 Kommentare
Thank you very much, the steps are very useful indeed and they helped tremendously when I got stuck!
Frankie SG - Antwort
Wonderful tutorial..
Emma MKay - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 28
Letzte 7 Tage: 149
Letzte 30 Tage: 586
Insgesamt: 16,422
