Zum Hauptinhalt wechseln
ZTE Maven Battery Replacement
Gigabit87898
Gigabit87898 und 3 weitere Mitwirkende
Zuletzt aktualisiert am February 8, 2022
Keine Schätzung
Mittel
Entfernen der Anleitung beantragen
Action Shots
Anleitung eines Community-Mitglieds
Follow this guide to remove and replace the battery for the ZTE Maven.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Was du brauchst
Werkzeuge
Mehr anzeigen …
    • Remove the back cover.
  1. ZTE Maven Battery Replacement: Schritt 2, Bild 1 von 2 ZTE Maven Battery Replacement: Schritt 2, Bild 2 von 2
    • If inserted, remove the SIM card and SD card.
    • Remove midframe screws.
    • Carefully pry between the screen and midframe to release the clips holding it on.
    • Remove the midframe.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Carefully, with a pry pick, pry under the battery to cut the adhesive underneath it.
    • If you are having trouble, apply a heated iOpener onto the battery for another minute, then try again.
    • You can also apply a few drops of high concentration isopropyl alcohol to the edges of the battery to help soften the adhesive.
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Gigabit87898
16.270 Reputation
3 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
327 Mitglieder
1.697 Anleitungen geschrieben
8 Kommentare
@gigabit87898 you should consider adding images for each step of any guide. A good guide points out where screws are located, what size they are and if they are all the same etc. It is not enough to write "Remove midframe screws". Remember, guides are written for anybody and keep in mind that people wanting to use your guide to fix their device, may not have your knowledge.
oldturkey03 - Antwort
yeah i dont think im going to use a “heat gun” on my battery
Vinny Games - Antwort
As long as you do it correctly, it will be fine.
Gigabit87898 -
I have a heat gun, but I think I’ll try a hair dryer first. In the comments under disassembly video at youtube one commenter said the adhesive is just double stick tape. Here’s the video: https://www.youtube.com/watch?v=LY5ltw1X...
Clint Murray - Antwort
Why heat the battery?? I need to change the screen in my moms maven and I'm kinda scared tbh. Lol the protective cover freaks me out!! Help me plzzzz?!?
CaRrIe 4TwIn E - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 3,849
