Zum Hauptinhalt wechseln
ZTE Prestige 2 Back Panel Removal
Mackenzie Peterson
Mackenzie Peterson und 3 weitere Mitwirkende
Zuletzt aktualisiert am September 29, 2021
10 Minuten
Mittel
This guide will help you replace the back panel in your ZTE Prestige 2. Before you start, check out our troubleshooting page that will help you decipher any basic problems before taking your device apart. Some reasons you may need to conduct this replacement is because there may be water damage or it may have fallen and cracked, resulting in it not fitting properly anymore. Before beginning, make sure to power off your device completely and disconnect from any external power source.
Was du brauchst
Werkzeuge
  1. ZTE Prestige 2 Back Panel Removal, Battery: Schritt 1, Bild 1 von 3 ZTE Prestige 2 Back Panel Removal, Battery: Schritt 1, Bild 2 von 3 ZTE Prestige 2 Back Panel Removal, Battery: Schritt 1, Bild 3 von 3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Back Panel Removal: Schritt 2, Bild 1 von 2 ZTE Prestige 2 Back Panel Removal: Schritt 2, Bild 2 von 2
    • Remove the battery.
  3. ZTE Prestige 2 Back Panel Removal, Back Panel: Schritt 3, Bild 1 von 3 ZTE Prestige 2 Back Panel Removal, Back Panel: Schritt 3, Bild 2 von 3 ZTE Prestige 2 Back Panel Removal, Back Panel: Schritt 3, Bild 3 von 3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Back Panel Removal: Schritt 4, Bild 1 von 3 ZTE Prestige 2 Back Panel Removal: Schritt 4, Bild 2 von 3 ZTE Prestige 2 Back Panel Removal: Schritt 4, Bild 3 von 3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
Abschluss
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Mitglied von UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 138
