iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement
Was du brauchst
Werkzeuge
Disconnect the hard drive thermal sensor from the top edge of the logic board.
Remove the two 9.2 mm T10 Torx screws securing the hard drive bracket to the rear case.
Lift the hard drive from its left edge enough to clear the inverter and pull it toward the left edge of your iMac to unseat the mounting pins from the chassis.
