Turn the power off and on again message
When i turn on the camera, the lens focusing two or three times open and close, then the message comes "TURN THE POWER OFF AND ON AGAIN" in the display.
Ist dies eine gute Frage?
The Sony Cybershot DSC-W55 was released in early in the year 2007. It is upgraded with a 7.2 megapixel camera compared to the previous model's 5.1 camera and has 56mb of internal memory.
balaji, this message most commonly appears when the lens does not fully retract or opens.
"Lens won't fully extend ¶
Screen shows Turn off and on again. ¶
Turn off the camera, remove the batteries from the camera and wait a few minutes. Replace the batteries and turn the camera on.
If the lens will still not extend, replace the batteries and turn the camera on.
If the lens will still not extend, check to see if there is any particles in the lens barrel. Blow air in the lens barrel to remove any sand or grit that may be preventing the lens from extending completely." I've had some good result by using a vacuum cleaner to assist the lend to extend and to clean it out. There is also more generic information about that on here. You will find a decent video (not exactly your model, but same problem), on youtube Hope this helps, good luck.
Kommentare:
I couldn't believe it; it worked on the third try. It didn't open at once but after leaving it on for a few seconds more than usual, it suddenly started working again. I had tried putting a piece of paper in between the shutters to dislodge anything too, an idea I got from the provided link.
von rhisiarthincs
i have sony w810 camera showing mesg on screen turn off and on again now what i do?
von muhammad
Excellent Thanks! Changed battery and used a high powered vacuum cleaner. So far so good!
von Gerry Kandler
excellent advise used the vacuum cleaner to clear sand then used a baby wipe to clean and lubricate
von mark250721
1. Throw the camera on a carpeted floor.
2. Blow on the lens.
3. Switch on the camera.
This is what I did when it said "Turn the power off and on again." It works fine now
Kommentare:
"Shock to the System" approach works! Start off with minimal velocity, increase as necessary until problem is solved (or camera shatters).
von MFMauceri
Thank you! Try to air flush dust as advice above .Same error "Turn off then on..."
Then i did your way .throw the camara on carpeted floor....Ta-da!! It works...
Really don't know what to say...but thanks for this method....It works for me...I just keep laugh now...Crazy...
von Minh Bui
i can't believe it it worked! thanks
von jessicamaesoria
Totally worked!! HAHAHA! I couldn't believe it. I had been trying to pry that lens open gently but it kept giving the error message. I don't have soft carpet at my work so I just threw the camera fairly hard onto my padded office chair. TADAAA! It worked! Thanks a bunch.
btw, I have the Sony Cyber-shot 10.1 mega pixel DSC-W180.
von Jerome Liwanag
I was at my last straws and did this . Worked for me.
von jasonoki
I had this issue and I managed to find a primitive fix, see my comment Shuts off after lens extends and retracts again.
What! No f'ing way! I threw it on my couch boom! Battery pops out. I pop it back in, turn it on! Done! Fyi. I have a very soft couch!
Rep: 1
Turn the power off and on agin problem
Rep: 1
Try to force rotate counterclockwise the back lens to force open it
Letzten 24 Stunden: 14
Letzten 7 Tage: 122
Letzten 30 Tage: 443
Insgesamt: 68,126
how can i fix it??
von Fadhili Madaraka
how can i fix ti problame
Fadhili Madaraka wht did you try? Did you check my answer below?
von oldturkey03
Turn power off and on again for the nth time...same problem
von may_mojica71
