Zum Hauptinhalt wechseln
Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
20 Fragen Alle anzeigen
Idle high, Overheating occurs quickly
1994 honda accord coupe had water pump replaced. Idling is high. Overheating occurs quickly. Cant figure out where the water is coming out of. Should radiator be replaced?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Is the water leaking? Checked the thermostat? what else did you check? do your fans come on?
von
Water is leaking. Fans come on. Thermostat was replaced. But there is water leaking from a area underneath the radiator.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Tina, check your radiator hoses to make sure they are properly clamped and that the hoses are okay. If so, it is possible that your radiator is leaking. Any shop should be able to do a pressure test to see exactly where it leaks. Yes, there is a distinct possibility that you may have to replace the radiator.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Tina wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,223
