Zum Hauptinhalt wechseln
Repair and disassembly information for Logitech's H800 wireless headset. Supports 2.4GHz & Bluetooth. Released in 2011. Model number: 981-000337.
19 Fragen Alle anzeigen
Micro-USB jack is broken
Ive recently broken the charging micro-usb jack on my h800 headset. At first i could charge if i put it in the right position making it impossible to use and charge the headset at the same time. Now it doesnt want to charge at all and i need to know if it is possible to get the jack replaced or just go buy a new headset.
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It's can be opened, but replacing the USB is not easy unless you have the correct tools.
War diese Antwort hilfreich?
Bewertung 1
You have to use hot air gun and iron.
Look near you for some repairing center or just somewhere where smartphones are repaired.
It will cost something about 20$ I think.
Bewertung 1
Antwort hinzufügen
Matache David wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 1,971
