Zum Hauptinhalt wechseln
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
Where is the fuel pump relay?
I need more specific answer for 1998 Mazda 626 four cylinder. Where is the fuel pump relay?
Is it the relay marked EGI or the Circuit Relay?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
What’s the one in the middle on the bottom of the picture??
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@yetbo check the fuse box in the engine compartment. There are a few varieties, white relay (green relay) same location. Sometimes labeled as EGI and sometimes as Circuit relay. Location is the same.
. You can find great information on here
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
the second pic is wrong
von
the first pic has a jumper running to the fuel pump
von
Antwort hinzufügen
boyett wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 69
Insgesamt: 16,641
