Zum Hauptinhalt wechseln
The Keystone KSTAD70A 70-pint Dehumidifier removes up to 70 pints of humidity from the air per day.
12 Fragen Alle anzeigen
Reconnect float in collector tank
I dropped the collector tank and the float came out. Reconnected it with the male pin on the float into the opening on the collector. Can't figure out, however how to make the other side stay in place. Can't find the shroud or whatever that held it loosely in place to swing. So now the machine always thinks that the tank is full and therefore won't run. Any help?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
There should have been a little plastic piece on each end to fit into holes. Do you think one of them broke off?
Mine just broke and I'm searching for a place to buy a replacement piece
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Michael Folloni wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 90
