Zum Hauptinhalt wechseln
LGs Flaggschiff-Smartphone mit einem einzigartigem herausschiebbarem Akku, abnehmbarem I/O Modul und Unterstützung für mehrere Hardwareerweiterungen. Erschienen im April 2016.
dropped phone down toilet
Dropped my lg g5 down the toilet I have dried it out and it seems to work but the touch screen comes on but does not respond when trying to access it but when the phone goes into stand by and you tap the screen it comes on but does not respond to touch is this a fault with the proximity sensor or the screen
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Ok ,I have had the same problem. Have dried my phone completely and started it up ,it has come on and is working just fine BUT it's slow working, eg. Opening of an app' is taking an exra 6seconds to open. The pages on screen are sort of sticking and responding quickly. Any help please.
von
Hi @andybutch ,
By 'dried completely', does that mean that you dis-assembled it and completely cleaned and dried it using IPA 90%+? This includes disconnecting flex cable connections and clean and dried connector sockets and cable ends as well as any other water affected components.
With liquid damage you have to ensure that everything has been cleaned and dried to prevent corrosion continuing or providing circuit disruptions.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi,
As you know water and electronics and electricity are not a good mix.
The minerals in the water (all water except distilled water) cause corrosion and water being a good conductor provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion process starts straight away
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that describes the process.
Electronics Water Damage
You may have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone.
LG G5
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
Hi the battery did not get wet it was only in the water for about a second
von
Hi,
Fair enough. I stated that it "may" have to be replaced, not that it will have to be replaced. A lot depends on how quickly it is removed from the phone. If the phone is still wet inside and the battery is still in, there is the potential for the battery to discharge to a point beyond recovery, even with the phone switched off, due to the water providing the electrical circuit paths.
von
Try opening it, and fill it with rice to completely dry it. After 24 hours, take the rice out and look at a teardown to see if your device is wired improperly.
Update 2/2/17
Actually not rice just dry it with a hair dryer but DO NOT microwave as that is dumb and stupid.
Update 3/2/17
Apperantly rice isnt the way to go, use Isopho whatever alcohol to clean the inside and remove corrosion.
Bewertung -1
3 Kommentare:
I have striped the phone down cleaned with alcohol seems to all be ok but the does not recognize touch
von
Hi @kurt_1411
IPA 90%+ or an UltraSonic cleaning bath are the only ways to ensure that the effects of water and corrosion are properly removed.
This link may be of interest to you.
Don't Put Your Device in Rice. Here's Why...
von
Hi @lesliejellicoe,
Did you disconnect the screen flex cable from the systemboard and clean the contacts on the end of the cable and in the board connector with IPA 90%+ as well?
Also use a magnifying glass to check the components on the systemboard to see if any are damaged (burnt or corroded).
von
Antwort hinzufügen
lesliejellicoe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 11,658
