cannot find any radio codes
i have a older Honda Accord [1996] the battery has been disconnected. cannot find any radio codes
Ist dies eine gute Frage?
Donny Armstrong , Remove radio at least partially so you can get the serial #, normally on a white tag. Write down the serial # or take a pic., now with your ownership in hand and serial # of radio you can drive to the Honda dealer, provide proof of ownership, give them the numbers, and get your code. You can also contact Honda at links below and hopefully they can email you a code if given all required info.. 1st link shows how to remove radio, 2nd and 3rd link is where you can contact Honda. Good luck.
https://www.youtube.com/watch?v=3hW5eM5F...
War diese Antwort hilfreich?
thanks alot for the info couldnt do it alone.
Donny, happy to be of assistance, good luck.
You can get a radio code here: https://radiocodevault.com/honda/
Hope it helps mate
If you can take out the radio and get the device serial number, you can look it up online at the site below. You will also need your VIN.
Hello, I think you should read the guide over at the below website, it will explain how you can get a radio code for your 1996 Honda Accord for free, give it a try. I've used it on both mine and my wifes Hondas and it worked perfectly both times. Beats paying the ridiculous fee at the main honda dealer!
94 honda accord radio serial number 146035 the code number is 52652
What about a 1995 Honda Civic coupe ex
Letzte 24 Stunden: 6
Letzte 7 Tage: 30
Letzte 30 Tage: 121
Insgesamt: 10,745
1 Kommentar
von James
